Hi everyone,
I have a question about processor expert.
It will generate the vector table : "__vect_table".
Why not "__vector_table"?
remark:
Processor Expert Software, Version: 10.0.0
Creare c project for MKL25Z128VLK4.
And the name "__vect_table" will cause some trouble when I compile with IAR.
The IAR will auto generate __vector_table if not find __vector_table.(even if I already have vector table : __vect_table)
So it will enlagre the executable file's size.
How to resolve it?
how to disable IAR generate __vector_table?
Thanks.
Solved! Go to Solution.
I have got info that this should be already fixed in the last version of driver suite.
best regards
Vojtech Filip
Processor Expert Support Team
best regards
Vojtech Filip
