I am developing on QSB using IAR and JTAG to lload to ram and run the application. We also tweak the QSB OBDS to burn the image to NOR using JTAG I need to be able to serially via uart burn the image to NOR. Is the MFG TOOL able to do that via UART.
Looking for suggestions. Thanks.
Solved! Go to Solution.
The MFG Tool only support USB. If you want to use UART, unfortunately we don't have document talk about this. You may need to customize it by yourself.
One option is ATK tool which support UART and USB. But it was a programming tool used for i.MX51, not for i.MX53. I think you can take it as a referene.
IMX_ATK_SOURCE_CODE (ver. 1.7)
