MC13213 Beekit with SRB and NCB
McGillMike
I am currently trying to figure out how to determine which keys were pressed, using the basic interrupt routines.
As soon as any key is pressed, an interrupt is generated, but from the documentation i found ,im unable to decipher between the keys.
Can anyone tell me how this would be done?
peg
Senior Contributor IV
Hi Mike,
The interrupt or hardware does not help you here.
It is up to you to read the port and figure out what key was pressed after the interrupt is recieved (just like you would if you didn't have an interrupt)
