P&E multilink different REVs matter ?
tmyint
On one of my PCs with Win 2000, it seems that the P&E usb multilink doesn't work at all. I dont know if it matters but I have Rev.C and Rev.D multilinks.
but on my other PC with WIN XP, the Rev.D version works but Rev.C version doesn't. Does having different versions matter at all as I thought they were all the same ?
admin
Specialist II
I would think that *something* significant had to change between rev. C and rev. D.  I had a multilink with and older rev on my XP machine (I don't remember what reve) and CW wanted to update it.  I just said "yes."  You might want to make sure you're running the same version of CW on each of your machines.  An older version of CW may not correctly recognize the new rev. of multilink.
-Tomahawk
admin
Specialist II
-Tomahawk
