MCF54415 SPI FLASH CAN NOT BOOTLOAD OCCASIONALLY WHEN POWER ON!
henrygore
when my mcf54415 board is power on, spi flash sometimes can not bootload correctlly,and then i push the manual reset key of the sp706s IC(external watchdog is bypassed),spi flash can bootload correctlly.From analysizing the waveform,i find that mcf54415 reads about 30~50 bytes from spi flash and then stops when power on. i wants to know what's
wrong,hardware circuit or uboot program? thahks
mikesnap
Henry
I am having a similar problem.
Did you find a solution?
Mike
