imxrt1052 connect pwm out to xbar out pin by xbar
ccc_clive
can i connect pwm out signal to xbar out pin by xbar?
MultipleMonomials
Yes, you can.  If you set the PWAOT0 and PWAOT1 bits in the PWMn->SMxTCTRL register, the PWM will generate its outputs on the FLEXPWMn_PWMx_OUT_TRIG0 and TRIG1 XBAR signals.  This will allow you to output PWM signals on any XBAR output pin of the device.
