Hi all,
In the debug environment of IAR the exaple "\flexspi\nor\polling_transfer" crashes.
After cold start everything works fine.
So debugging impossible...
WBR
Johann
Thank you for your patience.
I checked the example, by default on SDK 2.15.1 it comes linked to SRAM, it ran successfully on my side.
As it is linked to SRAM, after a reset, it gets errased. So, I suspect that your setup have the flexspi scatter file and XIP enable macros.
How did you imported the demo, using the CMSIS-Pack manager?
Testing for flexspi, I saw that the demo fails, so I made a report about this.
Diego
I remember you from this thread RT1170 EVKB fsl_romapi does not work. I presume that you are using SDk 2.15.1
Are you using J-Link or CMSIS DAP debugger?
Will work to see if I can replicate the issue on my end.
Thank you.
