Currently, I'm designing i.MXRT1050 application and have a question on the supply voltage.
NVCC_GPIO
According to IMXRT1050CEC.pdf, Table 9. Operating ranges, NVCC GPIO supply seems to be ok with 1.8V.
However, MIMXRT1050HDUG.pdf, Table 1. Power domains specify NVCC_GPIO with 3.3V only.
Does anyone have any idea which one is correct?
I'd like to have NVCC_GPIO with 1.8V supply. Will that be fine?
Thanks and Regards,
WS
Hi igorpadykov,
Thanks for the quick reply!
I'll have all NVCC_XX supplied with 1.8V as you confirmed.
Some of the specifications on i.MXRT1050 varies across each documentations, by the way.
Thanks and Regards,
WS
Hi Woo-Suk
you are right, latest rev.1.3 datasheet changed these specs,
so NVCC_GPIO is only 3 to 3.6V (and NOT 1.8V).
https://www.nxp.com/docs/en/data-sheet/IMXRT1050CEC.pdf
https://community.nxp.com/thread/503319
