Wire ACK FAULT
已解决
Wire ACK FAULT
跳至解决方案
454 次查看
sandeepc
when our team working project we faced Wire ACK fault.
While dumping code we are facing the Wire ACK fault. Some how we found the scenario to make to avoid the Wire ack Fault.
Working scenario:
1) power UP the board
2) Then connect the USB for Programming.
Fault Scenario:
A)
in this scenario if i remove the USB cable first and then removing power supply, it leads to Wire ack fault after this when even i follow the working condition procedure.
B)
1) connect the USB for Programming.
2) power UP the board.
        above this also leads to wire ack fault.
There is only way to overcome is by using MCUxpresso secure provisioning tool to write new image.
Any comments or suggestion please let mw know.
@RT1170 @kerryzhou @nxp
Sandeep C
1 解答
413 次查看
sandeepc
As per the MCU link user manual we need to remove R16 if we are facing  wire ack issue.
Sandeep C
在原帖中查看解决方案
5 回复数
414 次查看
sandeepc
Sandeep C
431 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, the scenario that you describe looks like a good behavior because the communication was lost through USB.
Is this scenario working in the past?
Pavel
422 次查看
sandeepc
Thanks for the reply
Even now also it's working with the first scenario(working scenario).
We need eliminate the fault scenarios.
Our requirements which ever we connect first it should work, either we connect USB or power up the board.
@Pavel_Hernandez
Sandeep C
419 次查看
Pavel_Hernandez
Hello, in other words, are you using a custom board?
Pavel
417 次查看
sandeepc
Yes,.
We are using custom board
Sandeep
