Where can I find information about the integrated battery charger and its registers?
imxrtuser
Senior Contributor I
I am trying to put the USB PHY to low power suspend mode (37.4.2.1 Entering Low Power Suspend Mode) in USB device mode.
If I follow the above procedure and step through my code with a debugger the USB PHY TX parts will
be automatically cleared (normal operation) after setting them to 1 by software (no USB cable is connected to my RT1020 EVK).
Maybe it is due to the battery charger bit not being set to 1. Where can I find information about the integrated battery charger and its registers? I can't find a chapter about the battery charger and its registers in the reference manual.
Kind regards,
Stefan
victorjimenez
Hello Stefan,
Could you please provide more information about the behavior that you are facing?
Victor
