SLN-ALEXA-IOT alternative
riteshEB
I am interested in developing Alexa built-in device using your solution mentioned in the Link
But SLN-ALEXA-IOT EVK is NRND. Also, it seems like 'AVS Integration with the AWS IoT' is deprecated by amazon and 'avs-device-sdk' is too big for MCU.
So do you recommend any alternate design or software SDK available which I can use for my application?
riteshEB
Hi @vicentegomez ,
Thanks for the reply. I know that imxrt106A is active. but my concern that 'SLN-ALEXA-IOT' software SDK is based on 'AVS Integration with the AWS IoT' instead of full 'avs-device-sdk' and as per amazon 'As of Nov 15, 2022, the AVS Integration with the AWS IoT program is no longer available.' Link
ST has the similar reference design. and they also NRND this design mentioning 'Amazon decided to maintain AVS for IoT system for existing products only. This solution can’t be used to develop a new product. Please contact Amazon for more information on AVS services.'
So just need to confirm, will this create a problem with amazon if I use nxp's alexa SDK in our product?
So that why i want confirmation before finalizing the software architecture of the product.
vicentegomez
Please contact your local sales representative to get more information
If you do not have any you can check our distributor on the next link
https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS
vicentegomez
the SLN-ALEXA-IOT use the imxrt106A that is active
is this device enough for your application?
regards
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
