The default SDK demo code should work at 1Ghz.
Hello
I hope you are well.
This Application note might be helpful: AN12437: i.MX RT Series Performance Optimization – Application Note (nxp.com)
Additionally, to reach that frequency on the consumer-grade product it is important that the voltage is on overdrive(1.1V - 1.15V) and enable FBB. You might want to use Config Tools to enable this frequency.
Omar
@Omar_Anguiano, Thanks a lot for your feedback.
I will keep you posted if I need additional support.
Kind regards,
ShaI
Hello team,
there is any update?
Kind regards,
Shai
