RT1020 - ETM trace with IAR IDE
JamesNgo
I'm having an RT1020 EVK and would like to use the following debugging feature:
ETM trace with IAR IDE. Current connection is SWD with J-Link v10.1 on J16 connector.
kerryzhou
Hi @JamesNgo
  About the RT1020 ETM trace, please check the NXP application note:
https://www.nxp.com/docs/en/application-note/AN12877.pdf
 As I know, it also need the debugger support the feature.
Wish it helps you!
kerry
JamesNgo
Thanks, Kerry.
I'd read the doc; however it requires:
1. Lauterbach JTAG module
2. Lauterbach TRACE32 software package
3. Target JTAG modifications
I'd like to make sure that JLINK + IAR limitation for not supporting the ETM tracing before I could consider the Lauterbach's.
kerryzhou
Hi @JamesNgo
  As I know, the ETM need your debugger to support it.
  Not all the JLINK can support the ETM trace function, you need to use the J-trace pro
https://www.segger.com/products/debug-probes/j-trace/models/j-trace/
This tool also support trace.
More details about the trace of the JLINK, you also can check with segger side.
Wish it helps you!
kerry
