Dear Friends,
I'm development a project with the MIMXRT1051 cross processor and I have a question: Can I use a QSPI Flash with size larger than 64Mb? The EVK (RT1050) use a QSPI Flash with size of 64Mb (IS25WP064), but I need use a QSPI Flash with size mininum of 256Mb (eg 256Mb, 512Mb or 1Gb).
Thanks a lot!
Solved! Go to Solution.
Hi Rubens Junior,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Table 2-1 demonstrates the system memory map of the i.MX RT1050, you can the FlexSPI can support the NOR flash whose size up to 504 MB.
TIC
Hi Rubens Junior,
TIC
