Dears,
We designed a board refer to RT1052-EVK, replaced the SDRAM with W9864G6KH-6. And running the demos, found error in Memory Viewer, can you please kindly help to advice?
BRs,
Ray
解決済! 解決策の投稿を見る。
Hi Ray,
W9864 only has 8bit column address. But RT1052 minimum column address is 9bit. I'm sorry that this SDRAM is not supported by RT1052.
Jing
Hi Ray,
Jing
Thanks, Jing Pan.
