Issue in SDK functions CLOCK_GetSysPfdFreq() and CLOCK_GetUsb1PfdFreq()
udoeb
These functions produce incorrect results for some PFD ratios, specifically for PFD=1 (FRAC=18). I reported this issue about two years ago and just found that the latest RT1011 and RT1061 SDK releases still include the bug. My original post describes the problem in detail and also shows how the code should be fixed.
Is this the right place to report SDK issue? If there is a better way, please advice.
Thank you.
Udo
Gavin_Jia
Hi @udoeb ,
We really appreciate your interest in NXP products.
I will submit this issue to R&D colleagues for discussion. I'll post the response here as soon as I have one, so please follow the progress of this thread.
Gavin
Gavin_Jia
Hi @udoeb ,
Hope you are doing well!
This is a synchronization letter. This issue is currently submitted to the internal team. I will sync you as soon as there is confirmation or if it will be fixed in the next release. Thank you for your contribution!
