Cs42448 audio card
Cs42448 audio card
1,111 次查看
Dhevan
     imxrt1060 application note i had seen 7.1 audio implementation (https://www.nxp.com/docs/en/application-note/AN13291.pdf).
    How to buy cs42448 audio card external board ?
   Vasu
886 次查看
brendonslade
We are setting up a separate page for the AUD-EXP-CS42448 right now, but for the moment its reachable from the i.MX RT1060-EVKB page and from there you can find a Buy link. Its in stock at our distributors at the moment, and should be in our web store soon.
Once the new page for this board is available it should appear at https://nxp.com/demoboard/AUD-EXP-CS42448
1,097 次查看
kerryzhou
Hi @Dhevan
  Internal information: your mentioned board will be published to the www.nxp.com, but the detail time is still not determined.
  If I get any detail information, will let you knwo.
Kerry
1,105 次查看
kerryzhou
Hi @Dhevan
  Seems that board still not be published, I also don't have it.
Tomorrow, I will help you check with our internal expert, and give you the updated information, please keep patient, thanks.
Kerry
