Clock gating in I.MXRT1176
Newton826
Hello All,
  I have a confusion regarding 400Mhz RC clock of I.MXRT1176.
1.In "OSC_400M_CTRL1" we have a gate bit
What does Gated means here, is it Gated ON/OFF?
Thank you,
Newton826
Thanks for the response.
Just needed to confirm once
Not Gated:- Clock is connected to peripherals
Gated :- Clock is disconnected from peripherals.
kerryzhou
Hi @Newton826 ,
  My understand is ON or off, the not gated is ON.
Wish it helps you!
kerry
Newton826
kerryzhou
Hi @Newton826 ,
  Yes, your description is more clear, the meaning is what your understanding.
Wish it helps you!
If your question is solved, please help to mark the correct answer, just to close this case.
Any new issues, welcome to create the new question post.
kerry
