I have been using the LVGL library in my project for a long time. Everything was fine. But I changed the display method. So normally I was using C Array format and displaying it. But now I'm using the .bin path and using open file functions. The GUI guide created some files for me. For example, lv_fs_rawfs.c and I merged it into my project. I am experiencing a bus fault problem when I try to fs_read the .bin file that I previously wrote to the XIP flash. What is the reason? Thank you.
Hi, @Gokberk
Whether your project in the port fatfs library, in the GUI Guider rt1060 component template there is sdcard demo can operate the file system, you can refer to.
I would like to know which code has a busfault during debugging? Was your project generated by GUI Guider?
Please tell me more about it.
Best regards, Alex
