AN13075 Software Download
JackyWu921
Hi guys,
   Where would I find the software files for AN13075: https://www.nxp.com/docs/en/application-note/AN13075.pdf . Has the software been released yet ?
Jacky
tzan
Hi Kelvin, Kerry,
I've just tried to download the application note software AN13075SW.zip from the link you provided but it seems corrupted.
I tried also to unzip it from Linux and from my smartphone with no luck, got same results: file corrupted.
Would you mind to send me an upgrade to this file, please?
many thanks!
T.
KelvinQi
Hi @JackyWu921
Here is the link of AN13075 software:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
Please select the 'Application Note Software' on the left menu, then you will see it.
Kelvin
kerryzhou
Hi @JackyWu921
  Please check the related code from the SDK:
SDK_2_10_0_MIMXRT1170-EVK\boards\evkmimxrt1170\vglite_examples
Then the detail code snip, just check your application note:
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
