1060 evk12 cannot debug
1,020 次查看
jingyangxie
I have a board(imxrt1060-evk12) ,when i use the sdk2.12.1 for 1060-evk, it cannot debug with flexspi_nor link file:
5 回复数
980 次查看
lucas_cao
Hi @Alice_Yang  and @jingyangxie
RT1060 EVK12 used HyperFlash as the boot device.
So if you are using RT1060's SDK, it makes sense that it cannot work well.
You can try RT1050 SDK becasue it uses HyperFlash as the boot device.
BTW, where did you get the RT1060 EVK12 board? By university program?
1,010 次查看
Hello @jingyangxie
It seems there is an issue with the boot jumper:
Have a look at :
https://www.nxp.com/document/guide/get-started-with-the-mimxrt1060-evk:GS-MIMXRT1060-EVK
Alice
993 次查看
jingyangxie
I have changed the SW7 to 0010, but it still doesn't work.the log as follows
986 次查看
Hello @jingyangxie
Which demo do you run? How about iled_blinky under SDK?
Alice
984 次查看
jingyangxie
it can not work too if I use the flexspi_nor.icf link file
