why does the value of MSTATUS register change in this way? base on RT685
melanie
BOARD_InitBootPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
result=I3C->MSTATUS; 0x1000
PRINTF("\r\nI3C master read sensor data example.\r\n");
I3C_MasterGetDefaultConfig(&masterConfig);
masterConfig.baudRate_Hz.i2cBaud = EXAMPLE_I2C_BAUDRATE;
masterConfig.baudRate_Hz.i3cPushPullBaud = 12500000U;
masterConfig.baudRate_Hz.i3cOpenDrainBaud = 4000000U;
masterConfig.enableOpenDrainStop = false;
I3C_MasterInit(EXAMPLE_MASTER, &masterConfig, I3C_MASTER_CLOCK_FREQUENCY);
result=I3C->MSTATUS;0x1101
why the value change?
0x1101 means the slave holds the SDA low, right? why?
is this value change right? why?
There is Slave Request in your I3C bus.
Alice
