is clarinox BLE stack free of charge for i.mxrt1170 ?
Mehmet_Ali
Dear Community,
I wonder if clarinox BLE stack is free of charge and if there are source codes available in mcuXpresso?
Thanks and best regards.
kerryzhou
Hi @Mehmet_Ali
  Our SDK bluetooth stack is free to use, you can refer to :
SDK_2_11_0_MIMXRT1170-EVK\boards\evkmimxrt1170\edgefast_bluetooth_examples
  For the other BLE stack which is not from NXP, you need to check with the related company.
  If you are using RT with bluetooth, I suggest you use the SDK related code and stack.
  Wish it helps you!
Kerry
