imxrt1060-evk flexspi-nor debug failed
415 次查看
jingyangxie
I use a 1060-evk board,when I use flexspi_nor link file in iar,it fails:
381 次查看
lucas_cao
Please make sure the boot mode switch is 0010, that means boot from QSPI flash.
389 次查看
Omar_Anguiano
Hello
Hope you are well.
Could you please give more details on the issue you are having? Which example are you trying to debug? Are you using an external debugger or the one in the EVK?
Are you using the latest version of the tools(IDE, SDK)?
Omar
