iMXRT1170 EVKB flexspi polling_transfer srash
371件の閲覧回数
johannzimmerman
Hi all,
In the debug environment of IAR the exaple "\flexspi\nor\polling_transfer" crashes.
After cold start everything works fine.
So debugging impossible...
WBR
Johann
3 返答(返信)
336件の閲覧回数
johannzimmerman
I did not change anything in the example.
IAR Compiler, CMSIS DAP debugger.
276件の閲覧回数
diego_charles
Hi @johannzimmerman
Thank you for your patience.
I checked the example, by default on SDK 2.15.1 it comes linked to SRAM, it ran successfully on my side.
As it is linked to SRAM, after a reset, it gets errased. So, I suspect that your setup have the flexspi scatter file and XIP enable macros.
How did you imported the demo, using the CMSIS-Pack manager?
Testing for flexspi, I saw that the demo fails, so I made a report about this.
Diego
349件の閲覧回数
diego_charles
Hi @johannzimmerman
I remember you from this thread RT1170 EVKB fsl_romapi does not work.  I presume that  you are using SDk 2.15.1
Are you using J-Link or CMSIS DAP debugger?
Will work to see if I can replicate the issue on my end.
Thank you.
