i.MXRT1051. How can I prevent programming via USB.
vanessa_dis
Hi everybody
For securiry reasons I would like to prevent temporarily programming via USB
I would like to be able to enable/disable this.
I hope somebody would help me, thank you.
Tags (3)
Alexis_A
Hello @vanessa_dis,
You could try blowing the fuse SDP_DISABLE to disable the serial downloader permanently but unfortunately there isn't a way to disable temporarily disable the serial downloader.
Alexis Andalon
Alexis_A
Hello @vanessa_dis,
Alexis Andalon
vanessa_dis
Thank you so much Alexis for your answer
