AN13778 refers to a VGLite Toolkit and user guide. Can someone please let me know where I can get access to these?
Thanks.
Hello, I hope you are well.
The tool is now available: Download Page - Email Alert (nxp.com)
Out of curiosity, what are your specific needs/intentions for the tool? Which RT device are you using?
Omar
Hello Omar,
Thanks for the download link. I don't suppose there is any planned support for a windows based VGTLite toolkit?
I'm currently evaluating the iMXRT1170 and wanted to use VGLite and Elemental to help check general graphics performance.
On a side note, do you know if there are any restrictions/considerations when trying to use VGLite on the CM4 core in the RT1170?
Dan.
I was able to run vglite on CM4 and it worked really well. I had issue though when CM4 was running from SDRAM when framebuffer is also placed because such configuration didn't work so I had to run CM4 from TCM.
