Using QSPI Flash in RT1050 with MCUXpresso v11.6.0 failed to program in J-Link v7.66e
1,287 次查看
felix1
The old method to delete FlashBankInfo tag in JLinkDevices.xml seems not work now for J-Link v7.66e installed with MCUXpresso v11.6.0.
Any advice?
https://community.nxp.com/t5/MCUXpresso-IDE/Can-not-find-segger-NXP-iMXRT105x-QSPI-elf-after-install...
标记 (1)
4 回复数
1,279 次查看
jay_heng
If you can not find related algo file under \SEGGER\JLink_V766e\Devices\NXP, it should be packed into JLinkARM.dll.
anyway, You can also try this algo:
超级下载算法RT-UFL v1.0发布,附J-Link下安装教程
超级下载算法RT-UFL v1.0在MCUXpresso IDE下的使用
1,249 次查看
felix1
Hi Jay,
I found the old method URL,
https://wiki.segger.com/index.php?title=i.MXRT1050&oldid=11727
for your reference.
1,254 次查看
felix1
Hi Jay,
according to https://wiki.segger.com/i.MXRT1050, I diff Hyper flash example NXP_MIMXRT1050-EVK_HyperFlash_EmbeddedStudio.zip and QSPI flash example NXP_MIMXRT1050-EVK_QSPI_EmbeddedStudio.zip ‎
In file MIMXRT1050-EVK_HyperFlash.emProject, the setting is arm_target_device_name="MIMXRT1051xxxxA" and
in file MIMXRT1050-EVK_QSPI.emProject, the setting is arm_target_device_name="MIMXRT1051xxxxA?BankAddr=0x60000000&Loader=QSPI".
How can I modify this setting in MCUXpressio IDE project?
p.s. I can't find JLinkDevices.xml file in J-Link v7.70d
1,270 次查看
felix1
Hi Jay,
I try your RT-UFL and receive the following message.
