Problems while running SmartWatch sample for RT595 EVB
1,504件の閲覧回数
sprhawk
I'm testing SmartWatch sample under ZephyrRTOS for RT595 EVB.
I encountered serveral problems:
1. the system crashed (z_arm_usage_fault) during startup inside board.c, while calling OTP_FUSE_READ_API. It can continue after I commented all callings to OTP_FUSE_READ_API.
2. After system started up after I fixed problem 1, it didn't show graphics on the LCD screen, and the log showed scrambled code after output of SmartWatch Demo `
it is indeed some proper printk:
タグ(1)
2 返答(返信)
1,481件の閲覧回数
sprhawk
About OTP_FUSE_READ_API, it crashed at the highlighted instruction
I didn't see somewhere the r10 is set to some value
1,253件の閲覧回数
diego_charles
Hi @sprhawk
My apologies for the delayed response, I just want to continue with the follow up for this.
The Smartwatch demo release v2.2 was recently published. Are you still  getting the issues with this update?
https://github.com/nxp-zephyr/apps_zephyr/tree/SmartWatch
Diego
