No examples run on m4 core
AlexCaron_teledyne
I'm currently evaluating the imxrt1170 for a new products and I can't get any example working on the m4 core. All example run perfectly on the m7, but for an unknown reason, they won't on the m4. In fact, the mculink is not connecting.
It's getting frustrating that even the provided examples are not working. Any clue on that? Is there something different between the m7 and m4 to program/lunch the debug ?
I'm working on the evaluation board.
PabloAvalos
Dear @AlexCaron_teledyne
Thanks a lot for reaching our technical support.
In regards to flash M4 core, you may use the example hello_world_demo_cm4 and hello_world_demo_cm7 to test both, by following the instructions on the readme.txt file. If the problem still persists, please attach some pictures or logs that appear to you regarding the errors so I can find what the root cause is.
Thanks a lot for your patience. I'll be stay tuned.
BR.
Pablo Avalos.
