Enter USB Serial Download from application on i.MX RT1172
383 次查看
andrealongobardi
I am looking for an SDK example or some guidelines to enter the USB Serial Download Mode directly from my application.
I wonder if someone could point me in the right direction. I have tried to follow this thread without success:
https://community.nxp.com/t5/i-MX-RT/Jump-to-ROM-bootloader-from-application-in-i-MX-RT1010/m-p/1684...
Thanks!!!
Andrea
370 次查看
kerryzhou
Hi @andrealongobardi ,
   To this method, normally have these way:
1. in your app, jump to the flashloader code, as the flashloader code can support the USB serial download.
  Normally, let the flashloader code story in the RAM, then jump to the flashloader, you can refer to this post:
https://www.nxpic.org.cn/module/forum/thread-620172-1-1.html
2. Use secondary bootloader
 After boot, it will stay in the serail download mode, can use the blhost do the USB HID connect the board, do the code downloading, or wait after the timeout and jump to your real app.
 You can refer to our SBL and SFW, that already support it.
https://github.com/nxp-mcuxpresso/sbl
https://github.com/nxp-mcuxpresso/sfw
This is the document:
https://www.nxp.com/docs/en/user-guide/MCUOTASBLSFWUG.pdf
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
