AN13291 CS42448 audio card software support?
502 次查看
g40
Is there any existing code, or Expresso project, or resources that produce a working audio card interface?
Many thanks.
449 次查看
g40
@kerryzhou Thank you. Extremely useful. Can the ZIP file be imported directly into MCUEspresso? I cannot see a .cproject file in the Zip.
419 次查看
kerryzhou
Hi @g40 ,
   I already checked software for the AN13291:
It is the IAR project, not the MCUXpresso IDE project, so you need :
use IAR IDE or porting the project to the mcuxpresso IDE with the source code by yourself.
Wish it helps you!
If you still have a question about it, please kindly let me know, thanks.
Kerry
488 次查看
kerryzhou
Hi @g40 ,
  Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
  Do you need the AN13291 an software?
  If yes, please download it from these link:
1. https://www.nxp.com/docs/en/application-note-software/AN13291SW1.zip
2.https://www.nxp.com/docs/en/application-note-software/AN13291SW2.zip
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
