no rule to make target
jonathansmyth
Can somebody tell me why i get this error?
JB4.2.2 imx6dl why are my libraries missing or what mus i do to have them generated
Copy: out/target/product/fsimx6dl_efusa9/root/fstab.freescale
make: *** No rule to make target 'out/target/product/fsimx6dl_efusa9/obj/STATIC_LIBRARIES/librecovery_ui_imx_intermediates/export_includes', needed by 'out/target/product/fsimx6dl_efusa9/obj/EXECUTABLES/recovery_intermediates/import_includes'.  Stop.
thanks
Labels (2)
jimmychan
problem may due to your Makefile:
for example:
SRC_FILES = \LF
    ch01.xml \LF
    ch02.xml \LF
    ref.xml \      LF
LF here is the line break.
please check if there have some spaces "       " after '\' . Then may cause this error. If it is the case, please try to remove the spaces between '\' and the LF. Then it should work.
