makeing kernel module
1,250件の閲覧回数
rudrapratapsing
#obj-m += hello.o ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- #CC=arm-none-linux-gnueabi- hello.o:hello.c #$(CROSS_COMPILE) $(CFLAGS) hello.c KDIR := /usr/src/L2.6.31_09.12.01_SDK_source/IMX-LTIB/ltib/rpm/BUILD/linux-2.6.31/kernel PWD := $(shell pwd) all: $(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules clean: $(MAKE) -C $(KDIR) SUBDIRS=$(PWD) clean the above is my makefile and my c code is given below #include /* Needed by all modules */ #include MODULE_AUTHOR(" Rudra Pratap Singh"); MODULE_LICENSE("GPL"); int init_module(void) { printk(<1> "Hello world 1.\n"); /* * A non 0 return means init_module failed; module can't be loaded. */ return 0; } void cleanup_module(void) { printk(<1> "Goodbye world 1.\n"); } module_init(init_module); module_exit(cleanup_module); it will shows some errors related to kernel tracepoint.h and marker.h. how to fix this??? please help me
タグ(2)
0 返答(返信)
