issue in SD card interface
5,392 次查看
mszeyghami
Hi friends,
I am using iMX6ull processor and want to extend my flash memory by using SD card peripheral. my emmc is 4G and I want to use 16G sd card as database storage. I've followed the official schematic. when I put the sd card in slot I see below log. what's the problem. I have checked the sd card pins with Oscilloscope, all pins have digital signals.
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SD card at address 0002
mmcblk0: mmc0:0002 965 MiB
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
mmc0: tried to reset card
mmcblk0: retrying using single block read
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 0
Buffer I/O error on dev mmcblk0, logical block 0, async page read
mmcblk0: unable to read partition table
the dts file content is like below:
&usdhc1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usdhc1>;
cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>;
keep-power-in-suspend;
enable-sdio-wakeup;
bus-width = <4>;
status = "okay";
标记 (1)
5,242 次查看
igorpadykov
Hi king
reason may be broken sd/emmc and one can try another device.
dts usdhc1 example can be found on:
imx6ull-14x14-evk.dts\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
5,242 次查看
mszeyghami
Thank you Igor
I have check with 3 different SD cards and the problem still persists
I use default dts file.
5,242 次查看
igorpadykov
for narrowing down problem one can try basic sd card tests, checking
signals with oscilloscope:
rt-thread/usdhc_test.c at master · RT-Thread/rt-thread · GitHub
