imx8mp uuu download failed (No udc Available!)
dskim2
Hello
I tried to download yocto image with uuu tool but failed
How can I fix it.
below is uuu and device log
[uuu log]
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.139-0-g1a8f760
Build in config:
Pctl Chip Vid Pid BcdVersion
SDPS: MX8QXP 0x1fc9 0x012f [0x0002..0xffff]
SDPS: MX8QM 0x1fc9 0x0129 [0x0002..0xffff]
SDPS: MX8DXL 0x1fc9 0x0147
SDPS: MX28 0x15a2 0x004f
SDPS: MX815 0x1fc9 0x013e
SDPS: MX865 0x1fc9 0x0146
SDPS: MX8ULP 0x1fc9 0x014a
SDPS: MX8ULP 0x1fc9 0x014b
SDP: MX7D 0x15a2 0x0076
SDP: MX6Q 0x15a2 0x0054
SDP: MX6D 0x15a2 0x0061
SDP: MX6SL 0x15a2 0x0063
SDP: MX6SX 0x15a2 0x0071
SDP: MX6UL 0x15a2 0x007d
SDP: MX6ULL 0x15a2 0x0080
SDP: MX6SLL 0x1fc9 0x0128
SDP: MX7ULP 0x1fc9 0x0126
SDP: MXRT106X 0x1fc9 0x0135
SDP: MX8MM 0x1fc9 0x0134
SDP: MX8MQ 0x1fc9 0x012b
SDPU: SPL 0x0525 0xb4a4 [0x0000..0x04ff]
SDPV: SPL1 0x0525 0xb4a4 [0x0500..0x9998]
SDPU: SPL 0x0525 0xb4a4 [0x9999..0x9999]
SDPU: SPL 0x3016 0x1001 [0x0000..0x04ff]
SDPV: SPL1 0x3016 0x1001 [0x0500..0x9998]
FBK: 0x066f 0x9afe
FBK: 0x066f 0x9bff
FB: 0x0525 0xa4a5
FB: 0x18d1 0x0d02
FB: 0x3016 0x0001
Wait for Known USB Device Appear...
New USB Device Attached at 2:141
2:141>Start Cmd:SDPS: boot -f imx8mp_flash_2G_4000.bin
100%2:141>Okay (1.894s)
2:141>Start Cmd:FB: ucmd setenv fastboot_dev mmc
2:141>Okay (0.022s)
2:141>Start Cmd:FB: ucmd setenv mmcdev ${emmc_dev}
2:141>Okay (0.313s)
2:141>Start Cmd:FB: flash bootloader imx8mp_flash_2G_4000.bin
0x400000002:141>Okay (0.432s)
2:141>Start Cmd:FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
2:141>Okay (0.011s)
2:141>Start Cmd:FB: ucmd setenv emmc_cmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
2:141>Okay (0.013s)
2:141>Start Cmd:FB: ucmd if test "${emmc_skip_fb}" != "yes"; then run emmc_cmd; fi
2:141>Okay (0.014s)
2:141>Start Cmd:FB: ucmd setenv emmc_cmd mmc bootbus ${emmc_dev} 2 2 1;
2:141>Okay (0.013s)
2:141>Okay (0.013s)
2:141>Start Cmd:FB: ucmd setenv fastboot_buffer ${loadaddr}
2:141>Okay (0.012s)
2:141>Start Cmd:FB: download -f Image
2:141>Okay (1.554s)
2:141>Start Cmd:FB: ucmd setenv fastboot_buffer ${fdt_addr}
2:141>Okay (0.012s)
2:141>Start Cmd:FB: download -f imx8mp-evk.dtb
2:141>Okay (0.025s)
2:141>Start Cmd:FB: ucmd setenv fastboot_buffer ${initrd_addr}
2:141>Okay (0.03s)
2:141>Start Cmd:FB: download -f fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.zst.u-boot
2:141>Okay (0.624s)
2:141>Start Cmd:FB: acmd ${kboot} ${loadaddr} ${initrd_addr} ${fdt_addr}
2:141>Okay (0.009s)
100%2:141>Okay (1.91s)
2:141>Okay (0.023s)
2:141>Okay (0.297s)
0x400000002:141>Okay (0.451s)
2:141>Okay (0.013s)
2:141>Okay (0.012s)
2:141>Okay (0.012s)
2:141>Okay (0.015s)
2:141>Okay (0.013s)
2:141>Okay (0.012s)
2:141>Okay (1.608s)
2:141>Okay (0.012s)
2:141>Okay (0.024s)
2:141>Okay (0.011s)
2:141>Okay (0.624s)
2:141>Okay (0.008s)
[Device log]
U-Boot SPL 2021.04-lf_v2021.04+g263b27e076 (Nov 22 2021 - 01:39:23 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0: RNG instantiated
Normal Boot
WDT: Not found!
Trying to boot from BOOTROM
Find img info 0x&480269a0, size 1032
Need continue download 1024
Download 1593520, Total size 1595152
NOTICE: BL31: v2.4(release):lf-5.10.72-2.2.0-0-g5782363f9
NOTICE: BL31: Built : 12:17:17, Nov 18 2021
U-Boot 2021.04-lf_v2021.04+g263b27e076 (Nov 22 2021 - 01:39:23 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
Model: NXP i.MX8MPlus LPDDR4 EVK board
DRAM: 2 GiB
tcpc_init: Can't find bus
setup_typec: tcpc port2 init failed, err=-22
setup_pd_switch: Can't find device id=0x72
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50]
MMC: FSL_SDHC: 1, FSL_SDHC: 2
Fail to setup video link
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF 5782363
MMC: no card present
Detect USB boot. Will enter fastboot mode!
Net:
Warning: ethernet@30be0000 (eth0) using random MAC address - 0a:1c:79:0d:7b:97
Warning: ethernet@30bf0000 (eth1) using random MAC address - fe:53:ba:8e:22:15
eth0: ethernet@30be0000, eth1: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for mfgtool
s
, using default environment
Run bootcmd_mfg: run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee}
= yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr}
${initrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot 0; fi;
Hit any key to stop autoboot: 0
## Checking Image at 43800000 ...
Unknown image format!
Run fastboot ...
flash target is MMC:1
MMC card init failed!
** Block device MMC 1 not supported
(NULL udevice *): request 00000000bdf1f900 was not queued to ep1in-bulk
flash target is MMC:2
Starting download of 1955600 bytes
downloading of 1955600 bytes finished
writing to partition 'bootloader'
Initializing 'bootloader'
switch to partitions #1, OK
mmc2(part 1) is current device
Writing 'bootloader'
MMC write: dev # 2, block # 0, count 3820 ... 3820 blocks written: OK
Writing 'bootloader' DONE!
Starting download of 32121344 bytes
downloading of 32121344 bytes finished
Starting download of 58085 bytes
downloading of 58085 bytes finished
Starting download of 12029289 bytes
downloading of 12029289 bytes finished
Moving Image from 0x40480000 to 0x40600000, end=42550000
## Loading init Ramdisk from Legacy Image at 43800000 ...
Image Name: fsl-image-mfgtool-initramfs-imx8
Created: 2011-04-05 23:00:00 UTC
Image Type: AArch64 Linux RAMDisk Image (uncompressed)
Data Size: 12029225 Bytes = 11.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Using Device Tree in place at 0000000043000000, end 00000000430112e4
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.22+g66e442bc7fdc (oe-user@oe-host) (aarch64-pok
y-linux-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.40.20230119) #1 SMP PREEMPT Mo
n Jun 12 12:31:27 UTC 2023
[ 0.000000] Machine model: NXP i.MX8MP SOM on AB2
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma':
size 960 MiB
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000094300000, s
ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@94300000, compatib
le id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff
[ 0.000000] NUMA: NODE_DATA [mem 0xbfbca700-0xbfbccfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000055ffffff]
[ 0.000000] node 0: [mem 0x0000000058000000-0x00000000923fffff]
[ 0.000000] node 0: [mem 0x0000000092400000-0x00000000943fffff]
[ 0.000000] node 0: [mem 0x0000000094400000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[ 0.000000] cma: Reserved 32 MiB at 0x00000000bba00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s44520 r8192 d29208 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 507904
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200,115200 rdinit=/linuxr
c clk_ignore_unused
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes,
linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes,
linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 1914504K/2064384K available (19584K kernel code, 1608K rw
data, 6708K rodata, 3328K init, 644K bss, 117112K reserved, 32768K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif
fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 21990
23255500ns
[ 0.000460] Console: colour dummy device 80x25
[ 0.000518] Calibrating delay loop (skipped), value calculated using timer fr
equency.. 16.00 BogoMIPS (lpj=32000)
[ 0.000528] pid_max: default: 32768 minimum: 301
[ 0.000579] LSM: Security Framework initializing
[ 0.000660] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, line
ar)
[ 0.000671] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes,
linear)
[ 0.001940] cblist_init_generic: Setting adjustable number of callback queues
[ 0.001951] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002019] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002172] rcu: Hierarchical SRCU implementation.
[ 0.002175] rcu: Max phase no-delay instances is 1000.
[ 0.003615] EFI services will not be available.
[ 0.003811] smp: Bringing up secondary CPUs ...
[ 0.004281] Detected VIPT I-cache on CPU1
[ 0.004356] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.004390] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.004864] Detected VIPT I-cache on CPU2
[ 0.004925] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.004943] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005374] Detected VIPT I-cache on CPU3
[ 0.005437] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.005454] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.005512] smp: Brought up 1 node, 4 CPUs
[ 0.005520] SMP: Total of 4 processors activated.
[ 0.005524] CPU features: detected: 32-bit EL0 Support
[ 0.005527] CPU features: detected: 32-bit EL1 Support
[ 0.005530] CPU features: detected: CRC32 instructions
[ 0.005584] CPU: All CPU(s) started at EL2
[ 0.005602] alternatives: applying system-wide alternatives
[ 0.007132] devtmpfs: initialized
[ 0.015380] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 7645041785100000 ns
[ 0.015400] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.016407] pinctrl core: initialized pinctrl subsystem
[ 0.019052] DMI not present or invalid.
[ 0.019617] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.020616] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.020863] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allo
cations
[ 0.021040] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al
locations
[ 0.021089] audit: initializing netlink subsys (disabled)
[ 0.021209] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=
0 res=1
[ 0.021700] thermal_sys: Registered thermal governor 'step_wise'
[ 0.021704] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.021736] cpuidle: using governor menu
[ 0.021915] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.021992] ASID allocator initialised with 65536 entries
[ 0.023104] Serial: AMBA PL011 UART driver
[ 0.023166] imx mu driver is registered.
[ 0.023187] imx rpmsg driver is registered.
[ 0.031671] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.043620] platform 32fc6000.lcd-controller: Fixed dependency cycle(s) with
/soc@0/bus@30c00000/hdmi@32fd8000
[ 0.048582] KASLR disabled due to lack of seed
[ 0.067197] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.067206] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.067211] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.067214] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.067220] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.067225] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.067231] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.067235] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.069040] ACPI: Interpreter disabled.
[ 0.069697] iommu: Default domain type: Translated
[ 0.069701] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.069962] SCSI subsystem initialized
[ 0.070255] usbcore: registered new interface driver usbfs
[ 0.070288] usbcore: registered new interface driver hub
[ 0.070315] usbcore: registered new device driver usb
[ 0.071450] mc: Linux media interface: v0.10
[ 0.071481] videodev: Linux video capture interface: v2.00
[ 0.071544] pps_core: LinuxPPS API ver. 1 registered
[ 0.071547] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[ 0.071560] PTP clock support registered
[ 0.071711] EDAC MC: Ver: 3.0.0
[ 0.072800] FPGA manager framework
[ 0.072872] Advanced Linux Sound Architecture Driver Initialized.
[ 0.073386] Bluetooth: Core ver 2.22
[ 0.073412] NET: Registered PF_BLUETOOTH protocol family
[ 0.073416] Bluetooth: HCI device and connection manager initialized
[ 0.073423] Bluetooth: HCI socket layer initialized
[ 0.073427] Bluetooth: L2CAP socket layer initialized
[ 0.073437] Bluetooth: SCO socket layer initialized
[ 0.073765] vgaarb: loaded
[ 0.074186] clocksource: Switched to clocksource arch_sys_counter
[ 0.074356] VFS: Disk quotas dquot_6.6.0
[ 0.074394] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.074545] pnp: PnP ACPI: disabled
[ 0.081198] NET: Registered PF_INET protocol family
[ 0.081360] IP idents hash table entries: 32768 (order: 6, 262144 bytes, line
ar)
[ 0.082894] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1638
4 bytes, linear)
[ 0.082945] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,
linear)
[ 0.082958] TCP established hash table entries: 16384 (order: 5, 131072 bytes
, linear)
[ 0.083070] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linea
r)
[ 0.083486] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.083568] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.083616] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.083758] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.084073] RPC: Registered named UNIX socket transport module.
[ 0.084077] RPC: Registered udp transport module.
[ 0.084080] RPC: Registered tcp transport module.
[ 0.084082] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.084791] PCI: CLS 0 bytes, default 64
[ 0.084991] Unpacking initramfs...
[ 0.094716] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
rs available
[ 0.095476] kvm [1]: IPA Size Limit: 40 bits
[ 0.096654] kvm [1]: GICv3: no GICV resource entry
[ 0.096662] kvm [1]: disabling GICv2 emulation
[ 0.096675] kvm [1]: GIC system register CPU interface enabled
[ 0.096814] kvm [1]: vgic interrupt IRQ9
[ 0.096896] kvm [1]: Hyp mode initialized successfully
[ 0.098054] Initialise system trusted keyrings
[ 0.098258] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 0.104153] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.104792] NFS: Registering the id_resolver key type
[ 0.104826] Key type id_resolver registered
[ 0.104829] Key type id_legacy registered
[ 0.104905] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.104910] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering
[ 0.104932] jffs2: version 2.2. (NAND) 짤 2001-2006 Red Hat, Inc.
[ 0.105261] 9p: Installing v9fs 9p2000 file system support
[ 0.141387] Key type asymmetric registered
[ 0.141401] Asymmetric key parser 'x509' registered
[ 0.141477] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
43)
[ 0.141483] io scheduler mq-deadline registered
[ 0.141487] io scheduler kyber registered
[ 0.148851] EINJ: ACPI disabled.
[ 0.161365] mxs-dma 33000000.dma-apbh: initialized
[ 0.168963] SoC: i.MX8MP revision 1.1
[ 0.172855] Bus freq driver module loaded
[ 0.179316] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.181971] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 17, base_baud
= 5000000) is a IMX
[ 0.182652] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 18, base_baud
= 5000000) is a IMX
[ 0.183146] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 19, base_baud
= 1500000) is a IMX
[ 0.707916] Freeing initrd memory: 11740K
[ 0.709691] printk: console [ttymxc1] enabled
[ 0.715331] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sd
ma/sdma-imx7d.bin failed with error -2
[ 1.311999] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback
for: imx/sdma/sdma-imx7d.bin
[ 1.316622] loop: module loaded
[ 1.326284] megasas: 07.719.03.00-rc1
[ 1.335318] spi-nor spi0.0: n25q256ax1 (32768 Kbytes)
[ 1.344800] tun: Universal TUN/TAP device driver, 1.6
[ 1.350906] thunder_xcv, ver 1.0
[ 1.354167] thunder_bgx, ver 1.0
[ 1.357439] nicpf, ver 1.0
[ 1.362423] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versio
n
[ 1.369658] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.375024] hclge is initializing
[ 1.378362] e1000: Intel(R) PRO/1000 Network Driver
[ 1.383247] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.389032] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.394005] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.399971] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.405410] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.411028] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.417308] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.423433] sky2: driver version 1.30
[ 1.427754] usbcore: registered new interface driver r8152
[ 1.433511] VFIO - User Level meta-driver version: 0.3
[ 1.442420] usbcore: registered new interface driver uas
[ 1.447785] usbcore: registered new interface driver usb-storage
[ 1.453852] usbcore: registered new interface driver usbserial_generic
[ 1.460413] usbserial: USB Serial support registered for generic
[ 1.466452] usbcore: registered new interface driver ftdi_sio
[ 1.472220] usbserial: USB Serial support registered for FTDI USB Serial Devi
ce
[ 1.479563] usbcore: registered new interface driver usb_serial_simple
[ 1.486116] usbserial: USB Serial support registered for carelink
[ 1.492229] usbserial: USB Serial support registered for zio
[ 1.497907] usbserial: USB Serial support registered for funsoft
[ 1.503933] usbserial: USB Serial support registered for flashloader
[ 1.510303] usbserial: USB Serial support registered for google
[ 1.516243] usbserial: USB Serial support registered for libtransistor
[ 1.522789] usbserial: USB Serial support registered for vivopay
[ 1.528820] usbserial: USB Serial support registered for moto_modem
[ 1.535109] usbserial: USB Serial support registered for motorola_tetra
[ 1.541743] usbserial: USB Serial support registered for nokia
[ 1.547593] usbserial: USB Serial support registered for novatel_gps
[ 1.553969] usbserial: USB Serial support registered for hp4x
[ 1.559736] usbserial: USB Serial support registered for suunto
[ 1.565676] usbserial: USB Serial support registered for siemens_mpi
[ 1.572063] usbcore: registered new interface driver usb_ehset_test
[ 1.581333] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/300
00000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.596044] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[ 1.602264] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-
01-01T00:00:00 UTC (0)
[ 1.611469] i2c_dev: i2c /dev entries driver
[ 1.620744] Bluetooth: HCI UART driver ver 2.3
[ 1.625213] Bluetooth: HCI UART protocol H4 registered
[ 1.630363] Bluetooth: HCI UART protocol BCSP registered
[ 1.635698] Bluetooth: HCI UART protocol LL registered
[ 1.640844] Bluetooth: HCI UART protocol ATH3K registered
[ 1.646265] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.652632] Bluetooth: HCI UART protocol Broadcom registered
[ 1.658322] Bluetooth: HCI UART protocol QCA registered
[ 1.663746] EDAC MC: ECC not enabled
[ 1.668770] sdhci: Secure Digital Host Controller Interface driver
[ 1.674972] sdhci: Copyright(c) Pierre Ossman
[ 1.680136] Synopsys Designware Multimedia Card Interface Driver
[ 1.686884] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.695138] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.702048] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.708998] usbcore: registered new interface driver usbhid
[ 1.714584] usbhid: USB HID core driver
[ 1.723363] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.723520] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.725509] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.746016] optee: probing for conduit method.
[ 1.750504] optee: revision 3.15 (c939619d)
[ 1.751382] optee: dynamic shared memory is enabled
[ 1.760852] optee: initialized driver
[ 1.767407] Galcore version 6.4.11.p1.658245
[ 1.790409] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml
on minor 0
[ 1.800170] hantrodec 0 : module inserted. Major = 510
[ 1.805877] hantrodec 1 : module inserted. Major = 510
[ 1.812639] hantroenc: HW at base <0000000038320000> with ID <0x80006200>
[ 1.819580] hx280enc: module inserted. Major <509>
[ 1.827031] NET: Registered PF_LLC protocol family
[ 1.833179] NET: Registered PF_INET6 protocol family
[ 1.839922] Segment Routing with IPv6
[ 1.843645] In-situ OAM (IOAM) with IPv6
[ 1.847659] NET: Registered PF_PACKET protocol family
[ 1.852756] bridge: filtering via arp/ip/ip6tables is no longer available by
default. Update your scripts to load br_netfilter if you need this.
[ 1.866677] Bluetooth: RFCOMM TTY layer initialized
[ 1.871597] Bluetooth: RFCOMM socket layer initialized
[ 1.876774] Bluetooth: RFCOMM ver 1.11
[ 1.880554] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.885904] Bluetooth: BNEP filters: protocol multicast
[ 1.891158] Bluetooth: BNEP socket layer initialized
[ 1.896139] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.902079] Bluetooth: HIDP socket layer initialized
[ 1.908013] 8021q: 802.1Q VLAN Support v1.8
[ 1.912241] lib80211: common routines for IEEE802.11 drivers
[ 1.918036] 9pnet: Installing 9P2000 support
[ 1.922449] Key type dns_resolver registered
[ 1.927445] registered taskstats version 1
[ 1.931591] Loading compiled-in X.509 certificates
[ 1.931885] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.943540] mmcblk2: mmc2:0001 DG4016 14.7 GiB
[ 1.949929] mmcblk2boot0: mmc2:0001 DG4016 4.00 MiB
[ 1.955984] mmcblk2boot1: mmc2:0001 DG4016 4.00 MiB
[ 1.959944] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[ 1.962007] mmcblk2rpmb: mmc2:0001 DG4016 4.00 MiB, chardev (234:0)
[ 1.978372] nxp-pca9450 0-0025: pca9450bc probed.
[ 1.983188] i2c i2c-0: IMX I2C adapter registered
[ 1.989071] pca953x 1-0020: supply vcc not found, using dummy regulator
[ 1.995788] pca953x 1-0020: using no AI
[ 1.999962] pca953x 1-0020: failed writing register
[ 2.005220] pca953x 1-0021: supply vcc not found, using dummy regulator
[ 2.011933] pca953x 1-0021: using no AI
[ 2.016095] pca953x 1-0021: failed writing register
[ 2.021189] i2c i2c-1: IMX I2C adapter registered
[ 2.027018] pca953x 2-0020: supply vcc not found, using dummy regulator
[ 2.033738] pca953x 2-0020: using no AI
[ 2.038130] pca953x 2-0020: failed writing register
[ 2.044081] i2c i2c-2: IMX I2C adapter registered
[ 2.059009] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with
HDCP (samsung_dw_hdmi_phy2)
[ 2.070647] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driv
er
[ 2.082496] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_
crtc_ops)
[ 2.090483] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_o
ps)
[ 2.098786] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on
minor 1
[ 2.106692] imx-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.117393] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[ 2.124489] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[ 2.131311] imx-dwmac 30bf0000.ethernet: DWMAC4/5
[ 2.136115] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[ 2.143258] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[ 2.150401] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[ 2.157110] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[ 2.163259] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog
Timer
[ 2.170938] imx-dwmac 30bf0000.ethernet: device MAC address a6:03:10:dd:59:f7
[ 2.178084] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 2.184884] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 2.191686] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off
=256)
[ 2.199272] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device wid
th
[ 2.214373] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 su
pported-hw 0x80 0x4
[ 2.224119] Hot alarm is canceled. GPU3D clock will return to 64/64
[ 2.233560] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 2.235471] cfg80211: Loading compiled-in X.509 certificates for regulatory d
atabase
[ 2.251204] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.257837] platform regulatory.0: Direct firmware load for regulatory.db fai
led with error -2
[ 2.266467] platform regulatory.0: Falling back to sysfs fallback for: regula
tory.db
[ 2.266507] clk: Not disabling unused clocks
[ 2.274368] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.278515] ALSA device list:
[ 2.288511] No soundcards found.
[ 2.293287] Freeing unused kernel memory: 3328K
[ 2.314256] Run /linuxrc as init process
No udc Available!
No udc Available!
No udc Available!
[ 12.515257] platform gpio-reset: deferred probe pending
No udc Available!
No udc Available!
No udc Available!
No udc Available!
dskim2
I used new uuu tool please below uuu tool version
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.21-0-g1f42172
jogt
did you find any solution?
xjy198903
Configure usb as host mode in the kernel and try.
jogt
In my case, as I compiled a modified kernel and rootfs using buildroot. I just had missed adding the bash package to run "imx-uuu-init" after init. Now, everything is working on my end.
xjy198903
I'm also experiencing this problem, how can I solve it
