imx8mm qt opengl
imx8mm qt opengl
1,393件の閲覧回数
lizuobin
      I found some problems when testing imx8mm evk.
      /usr/share/qt5/examples/opengl/qopenglwidget/qopenglwidget
 Text and partial graphics are drawn incorrectly, you can see the background of the weston,
How to solve this problem?
3 返答(返信)
1,237件の閲覧回数
Bio_TICFSL
Hello li,
There must be some missconfiguration in color of the LCD, to be frankly try to burn the image again if the same issue happens then try to change the configuration of the LCD.
1,237件の閲覧回数
lizuobin
HI,
thanks for your reply,I am using the image provided in L4.14.98_2.0.0_ga_images_MX8MMEVK, I don't think this is a problem with the LCD driver, because only opengl related programs will have the above problem.
thanks.
933件の閲覧回数
sakizci
Hello li,
did you solve this problem? if you solved it can you share it with me ?
