iMx8qxp X11 EGL OpenGLES2
clement_gervais
I work on a iMx8qxp (Linux 4.14.98_2.0.0_ga) and I would like to know if someone has used X11 + EGL + OpenGLES2 on this platform for generating a C application.
Indeed, I tried to execute a code with X11 + EGL + OpenGLES2 in C language but it returns a segmentation fault after eglInitialize().
However, I'm able to :
- Build a C application using Wayland + EGL + OpenGLES2;
- Build a C application that creates a simple X11 window;
But now, I'm interesting to use X11 with EGL and Open GLES2 on the iMx8qxp.
Thank you in advance for your feedback,
Clément
Bio_TICFSL
Hello Clément,
Yes, karan.gajjar@volansystech.com‌ is right X11 is not supported in MX8.
clement_gervais
Hi Karan Gajjar and Bio_TICFSL,
Thank you for your response.
I will use Wayland for my application.
Clément
karangajjar
Senior Contributor II
Hi Clément Gervais ,
As per https://www.nxp.com/webapp/Download?colCode=imx-yocto-L4.14.98_2.0.0_ga&location=null  i.MX_Yocto_Project_User's_Guide.pdf, X11 graphics are not supported in i.MX 8.
Karan Gajjar
