iMX7Solo/Dual DDR bit swapping
858 次查看
igal_kagan
Hello.
I'm designing the board with iMX7S processor. I'm using LPDDR2 memory for this application.
Is it possible to swap bits inside the data lanes for simplifying PCB layout? (I didn't find any mention on it in application notes or datasheet).
I would be grateful for your prompt reply.
Igor.
标签 (2)
846 次查看
igorpadykov
Hi Igor
this is general question, for example answer can be found on
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Zynq-LPDDR2-DQ-Swap-Question/td-p/39686...
847 次查看
igorpadykov
Hi Igor
