iMX6ULL, Linux 4.1.15, how to use EPIT to implement accurate periodic interrupts?
ソリューションへジャンプ
2,951件の閲覧回数
JanieZee
I want to use EPIT to achieve an interrupt every 156us, but actual tests have found that the interrupt interval is not precisely 156us, with some intervals even reaching the millisecond level.
Why is this happening? What should I do to achieve an accurate 156us periodic interrupt?
2,916件の閲覧回数
Zhiming_Liu
4 返答(返信)
2,922件の閲覧回数
Zhiming_Liu
How do you call the epit function in your test? Have you write EPIT driver by yourself?
2,920件の閲覧回数
JanieZee
Yes, this is the EPIT driver. Additionally, I have set CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y, but the interrupt interval is still not accurate.
2,917件の閲覧回数
Zhiming_Liu
1,426件の閲覧回数
bighero77
for the first method. the code is here. but would not been build
how can I make this file build?
thanks.
https://github.com/nxp-imx/linux-imx/blob/imx_4.1.15_2.0.0_ga/arch/arm/mach-imx/epit.c
