iMX51 I2C bus clock stops and slave is stuck in mid-transmission.
satank
A common I2C bus error is slave devices that have ended up in a state where Data (the data line) is low. Typically a master performs error recovery by clocking the Clock line until the Data line is high and then issuing a Start followed by a Stop.
Further explination of the problem is described at:
http://www.analog.com/static/imported-files/application_notes/54305147357414AN686_0.pdf
Does anyone have a Linux driver patch to perform the bus recovery by toggling the SCL line until SDA line is released again?
Rick S
