i.MX8MQ EVK can not powerdown with poweroff or halt command
746 次查看
bakbad
Hello, NXP
When I used poweroff or halt, reboot command in linux-4.9.88 , they can not work.And i have uploaded the log from serial. Could you give me some help with this problem。
bo xu
标签 (2)
574 次查看
jimmychan
According to BSP team, this problem occurs because of an Wi-Fi issue.
You can reboot the board if you change kernel parameters.
Add "pci=nomsi"  to mmcargs in u-boot in order to fix Wi-Fi.
574 次查看
bakbad
Hi jimmychan,
Thanks for your advice.
Best Regards.
