i.MX8MM-Evk eMMC commands
370 次查看
vignesh-baskaran
We Having i.MX8MM-Evk,
We were trying to send custom commands as per 5.1 specs. But we were unable to send commands.
How to disable initialization of card and we want write our own application to send all commands manually specs supports at userspace.
We don't want it to be partitioned. it has to be detected as mmcblk device.
Can you please gives us any suggestions or any way to do it?
336 次查看
Bio_TICFSL
Hello
If you don't want partition that you muts have that partitition on another SD, I'm clear? which 5.1 are you referring to? the steps to burn your SD requires partition if not the BSP don't run, please clarify.
