i.MX8M plus 1920x720 resolution
zhilong
I am using a core board from Advantech
The HDMI interface connects to a 1920 * 720 resolution screen, but when board powered on, the HDMI port defaults to outputting 1920 * 1080. May I ask what is the solution?
Zhiming_Liu
Hi @zhilong
There is no compatible timing for this , please contact Advantech to create a case about this issue.
Need generate new timing table.
