i.MX8M Mini EL1 stack pointer Issue
Hariharan1
In arm cortex a53, I am switching exception level EL3 to EL1. I attached code below.
mov x0, xzr
mov x0, #0b00101 /* EL1 */
orr x0, x0, #(3 << 8)/* Enable SError and Debug Abort. */
orr x0, x0, #(1 << 7) /* IRQ interrupt Process state mask. */
orr x0, x0, #(1 << 6) /* FIQ interrupt Process state mask. */
msr spsr_el3, x0
ldr x0, =el1_secure
msr elr_el3, x0
isb
eret
I checked Currentel register, it has changed exception level (EL1). after that stack pointer pointing to somewhere. i don't know why.
mrs x6, Currentel
ubfx x6, x6, #2, #2
Here is example of stack pointer register
x30 0x7e1190
sp 0xddd141a18806092b
pc 0x910e3c <main+4>
cpsr 0xaaaaaaaa [ #1 #3 #5 I D #11 #13 #15 #17 #19 SS UAO TCO #27 C N ]
anyone recommend your thoughts what i have to do clear that error.
Zhiming_Liu
We don't support such issue, you should refer the ELx switch code in uboot, atf or kernel.
