[i.MX8] How to record screen on weston.
tan-k
We are testing i.MX8 with below environment.
[Environment]
Evaluation Kit : 8MMINILPD4-EVK (Connect HDMI cable, USB keyboard and USB mouse.)
Linux for i.MX : Linux 5.10.9_1.0.0
We can capture a screenshot with "super" + "s" key.
We also try to record a screencast with "super" + "r" key.
"capture.wcap" file is created.
However file size is not changed.
According to weston.log, total file size is 0M and 0 frames.
# ls -l /home/weston/capture.wcap
-rw-r--r-- 1 root root 16 Jul 19 07:37 /home/weston/capture.wcap
# cat /run/user/0/weston.log
[07:37:33.909] starting recorder for output HDMI-A-1, file capture.wcap
[07:58:19.181] stopping recorder, total file size 0M, 0 frames
How can I record screen on weston?
shaioz
late for the thread but for others, I've run into the exact same problem and for me what worked is to comment this line in the weston config file:
use-g2d=1
then restart weston.
Good luck!
Rita_Wang
The screenshot is support in weston, but record screen can not support
You can run the QT, the Qt's grabWindow() to achieve the task.
tan-k
Thank you for your reply!
We will try to use Qt's grabWindow() instead of Weston record screen.
Do you have any examples to record screen?
mgonzalezg9
Hi, did you find any example of Qt or Python screen capture?
Rita_Wang
Sorry I do not have.
tan-k
OK, thank you.
By the way, could you please let us know the documents or URL about not supporting record screen function?
Where does it say that?
