Is there a list datasheet of signal names (src_bt_cfg, 6 or usdhc_data, 3, etc.) that can be assigned to each port?
This is because I want to compare the output result of config tool for i.MX v7 with the signal name. (Html_report_Pins.html)
regard
In addition to the DataSheet you can refer to i.MX6ULL Reference Manual:
https://www.nxp.com/webapp/Download?colCode=IMX6ULLRM
