Hi :
I have a i.mx53 qsb board,and downloaded android source and mx patch.
The i.mx53 System Development User's Guide version is 1.3/2011.
In the document,on page 10-2,the chapter 10.2.1 UART(Serial port) test.
I can not fild the hardware.c file,and can not find the "debug_uart" variable in imx53.c(or mx53_xx.c),and also can not find the function "debug_uart_iomux()"in
all download codes.
How can i download the right user guide document? thanks
On the i.MX53 reference boards (with the exception of the ARD), the UART1 TXD and RXD pins are
routed to the CSI0_DAT10 and CSI0_DAT11 pins via the IOMUX (see the
~/diag-obds/src/mx53/hardware.c file). In addition, the file mx53.c defines the “debug_uart” variable to
UART1 as static struct hw_module *debug_uart = &uart1; If a different UART por t is used, make the
required IOMUX changes to the routine debug_uart_iomux() , using the following code:
The i.mx53 System Development User's Guide relates to Linux BSP.
Thanks for your apply.
1.for my question,i find the obds source code in freescale website.but can not make sucessed.can you give me some step for make obds.
follow msg is the error.i think may be modifty the makefile ,but i do not know how to modifty it or just in Android Compile enviroment it can make sucessed.
make[4]: arm-none-eabi-gcc:命令未找到
make[4]: *** [/home/huzizhen/myandroid/MX53_OBDS/output/mx53/obj/imx_usb/usb_h1.o] 错误 127
make[4]:正在离开目录 `/home/huzizhen/myandroid/MX53_OBDS/src/drivers/usb/imx_usb'
make[3]: *** [imx_usb] 错误 2
make[3]:正在离开目录 `/home/huzizhen/myandroid/MX53_OBDS/src/drivers/usb'
make[2]: *** [usb] 错误 2
make[2]:正在离开目录 `/home/huzizhen/myandroid/MX53_OBDS/src/drivers'
make[1]: *** [drivers] 错误 2
make[1]:正在离开目录 `/home/huzizhen/myandroid/MX53_OBDS/src'
make: *** [src] 错误 2
2.the other question,about The i.mx53 System Development User's Guide relates to Linux BSP,i can only find the i.mx53 System Development User's Guide.where can download the i.mx53 System Development User's Guide relates to Linux BSP
Perhaps it would be easier to build the OBDS under Windows or Linux environment
thanks for your apply.
I'm downloading cgywin for 2 days,it always failed.can you give me a zip?
You may use CodeSourcery Lite under Windows - no need for Cygwin.
CodeSourcery is now Mentor Graphics Sourcery Tools - Mentor Graphics
thanks for your reply.
I download and install arm-2013.05-24-arm-none-linux-gnueabi.exe,with the user guide ,i build a c sample code sucessed.
but i do not know how to build the OBDS.follow the OBDS release note ,use the command "make TARGET=mx53 BOARD=sbrth_lcb BOARD_VERSION=1",the result is make command can not find. Can you give me a suggestion.
It is named "cs-make.exe" in d:\Program Files\CodeSourcery\Sourcery G++ Lite\bin\ :
just copy it as make.exe or rename.
Hi:
The sourcery can not support linux command or some libs i do not installed.
Today,my cygwin is installed suceesed. And I copy I201139_mx53_sbrth_lcb_release to cygwin .
Then ,run Cygwin Terminal in windows xp.
Enter the I201139_mx53_sbrth_lcb_release, do "make TARGET=mx53 BOARD=sbrth_lcb BOARD_VERSION=1",
there are some error code :
$ make TARGET=mx53 BOARD=sbrth_lcb BOARD_VERSION=1
mkdir -p output
mkdir -p output/mx53
mkdir -p G:\cygwin\home\I201139_mx53_sbrth_lcb_release/output/mx53/lib
mkdir -p G:\cygwin\home\I201139_mx53_sbrth_lcb_release/output/mx53/bin
make -S -C src dir
make[1]: 进入目录“/home/I201139_mx53_sbrth_lcb_release/src”
G:\cygwin\home\I201139_mx53_sbrth_lcb_release/make.rules:10: *** 目标模式不含有
“%”。 停止。
make[1]: 离开目录“/home/I201139_mx53_sbrth_lcb_release/src”
makefile:48: recipe for target `src' failed
make: *** [src] Error 2
can you give me some help?
Thanks for your reply.
That linux command can not support.eg mkdir
发自我的 iPad
在 2013-7-19,12:22,Yuri Muhin <admin@community.freescale.com> 写道:
about imx53 System Development User's Guide
created by Yuri Muhin in i.MX Community - View the full discussion
Reply to this message by replying to this email -or- go to the message on Freescale Community
Start a new discussion in i.MX Community by email or at Freescale Community
Template inclusion failed (for parameter value "theme-lib.common-functions"): /home/lithium/customer/nxp.prod/plugins.export/custom/nxp/nxp/prod/res/macros/theme-lib.common-functions.ftl (No such file or directory) ---- FTL stack trace ("~" means nesting-related): - Failed at: #include "theme-lib.common-functions" [in template "theme-lib.ui-script.profile-card" at line 1, column 1] ---- Java stack trace (for programmers): ---- freemarker.core._MiscTemplateException: [... Exception message was already printed; see it above ...] at freemarker.core.Include.accept(Include.java:164) at freemarker.core.Environment.visit(Environment.java:326) at freemarker.core.Environment.visit(Environment.java:332) at freemarker.core.Environment.process(Environment.java:305) at freemarker.template.Template.process(Template.java:378) at lithium.customize.freemarker.FreeMarkerService.processTemplate(FreeMarkerService.java:95) at lithium.template.CustomTemplateFreeMarkerParser.parseInlineTemplateThrowException(CustomTemplateFreeMarkerParser.java:196) at lithium.template.CustomTemplateFreeMarkerParser.parseInlineTemplate(CustomTemplateFreeMarkerParser.java:225) at $CustomTemplateParser_3e99bee971c7c3.parseInlineTemplate(Unknown Source) at $CustomTemplateParser_3e99bee971c6d5.parseInlineTemplate(Unknown Source) at lithium.web2.services.layout.CustomComponentTemplateRenderable.render(CustomComponentTemplateRenderable.java:85) at lithium.tapestry.services.components.CssClassRenderableDecorator$1.render(CssClassRenderableDecorator.java:64) at org.apache.tapestry5.internal.services.RenderQueueImpl.run(RenderQueueImpl.java:72) at org.apache.tapestry5.internal.services.PageRenderQueueImpl.render(PageRenderQueueImpl.java:124) at $PageRenderQueue_3e99bee971c7a5.render(Unknown Source) at $PageRenderQueue_3e99bee971c7a4.render(Unknown Source) at org.apache.tapestry5.internal.services.MarkupRendererTerminator.renderMarkup(MarkupRendererTerminator.java:37) at org.apache.tapestry5.services.TapestryModule$31.renderMarkup(TapestryModule.java:1993) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at org.apache.tapestry5.services.TapestryModule$30.renderMarkup(TapestryModule.java:1977) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at org.apache.tapestry5.services.TapestryModule$29.renderMarkup(TapestryModule.java:1959) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at org.apache.tapestry5.services.TapestryModule$27.renderMarkup(TapestryModule.java:1930) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRendererFilter_3e99bee971c7a7.renderMarkup(Unknown Source) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.web2.services.util.TapestryDefaultCssMarkupRenderer.renderMarkup(TapestryDefaultCssMarkupRenderer.java:59) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at org.apache.tapestry5.services.TapestryModule$26.renderMarkup(TapestryModule.java:1912) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at org.apache.tapestry5.services.TapestryModule$25.renderMarkup(TapestryModule.java:1893) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTraceMarkupRendererFilter.renderMarkup(AbstractAppTraceMarkupRendererFilter.java:85) at $MarkupRenderer_3e99bee971c7b7.renderMarkup(Unknown Source) at $MarkupRenderer_3e99bee971c7a3.renderMarkup(Unknown Source) at org.apache.tapestry5.internal.services.PageMarkupRendererImpl.renderPageMarkup(PageMarkupRendererImpl.java:47) at $PageMarkupRenderer_3e99bee971c7a1.renderPageMarkup(Unknown Source) at org.apache.tapestry5.internal.services.PageResponseRendererImpl.renderPageResponse(PageResponseRendererImpl.java:67) at $PageResponseRenderer_3e99bee971c639.renderPageResponse(Unknown Source) at org.apache.tapestry5.internal.services.PageRenderRequestHandlerImpl.handle(PageRenderRequestHandlerImpl.java:64) at org.apache.tapestry5.services.TapestryModule$38.handle(TapestryModule.java:2221) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.web2.services.reporting.ReportingPageContextRequestFilter.handle(ReportingPageContextRequestFilter.java:71) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:62) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.delegate(AbstractAppTracePageRenderRequestFilter.java:39) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:143) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestFilter.handle(AbstractAppTracePageRenderRequestFilter.java:39) at $PageRenderRequestHandler_3e99bee971c63b.handle(Unknown Source) at lithium.studio.web.common.services.publish.PublishWorkflowPageRenderRequestHandler.handle(PublishWorkflowPageRenderRequestHandler.java:67) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.studio.web.common.services.StudioPublishPreviewPageRenderRequestHandlerDecorator.handle(StudioPublishPreviewPageRenderRequestHandlerDecorator.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:49) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.delegate(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.tapestry.services.trace.AbstractAppTraceRequestHandler.handle(AbstractAppTraceRequestHandler.java:122) at lithium.tapestry.services.trace.AbstractAppTracePageRenderRequestHandler.handle(AbstractAppTracePageRenderRequestHandler.java:35) at lithium.web2.services.exceptions.ExceptionPageRenderRequestHandlerDecorator.handle(ExceptionPageRenderRequestHandlerDecorator.java:72) at lithium.wireless.web.common.services.WirelessSupportPageRenderRequestHandlerDecorator.handle(WirelessSupportPageRenderRequestHandlerDecorator.java:84) at lithium.lia.components.tapestry.services.page.CurrentPagePageRenderRequestHandlerDecorator.handle(CurrentPagePageRenderRequestHandlerDecorator.java:83) at $PageRenderRequestHandler_3e99bee971c62d.handle(Unknown Source) at org.apache.tapestry5.internal.services.ComponentRequestHandlerTerminator.handlePageRender(ComponentRequestHandlerTerminator.java:48) at org.apache.tapestry5.services.InitializeActivePageName.handlePageRender(InitializeActivePageName.java:47) at $ComponentRequestHandler_3e99bee971c62e.handlePageRender(Unknown Source) at $ComponentRequestHandler_3e99bee971c5f1.handlePageRender(Unknown Source) at org.apache.tapestry5.internal.services.PageRenderDispatcher.dispatch(PageRenderDispatcher.java:45) at $Dispatcher_3e99bee971c5f4.dispatch(Unknown Source) at $Dispatcher_3e99bee971c5b6.dispatch(Unknown Source) at org.apache.tapestry5.services.TapestryModule$RequestHandlerTerminator.service(TapestryModule.java:302) at lithium.web2.services.search.SearchRequestFilter.service(SearchRequestFilter.java:95) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.web2.services.routes.RoutesFilter.service(RoutesFilter.java:109) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.web2.services.mobile.MobileRequestFilter.service(MobileRequestFilter.java:174) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.kudos.web.common.services.KudosRewriteFilter.service(KudosRewriteFilter.java:79) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.web2.services.feature.PageVersionRequestFilter.service(PageVersionRequestFilter.java:185) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.wireless.web.common.services.WirelessRequestFilter.service(WirelessRequestFilter.java:186) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at lithium.web2.services.seourl.SeoRequestFilter.service(SeoRequestFilter.java:80) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at org.apache.tapestry5.internal.services.RequestErrorFilter.service(RequestErrorFilter.java:26) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at org.apache.tapestry5.services.TapestryModule$3.service(TapestryModule.java:902) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at org.apache.tapestry5.services.TapestryModule$2.service(TapestryModule.java:892) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at org.apache.tapestry5.internal.services.StaticFilesFilter.service(StaticFilesFilter.java:90) at $RequestHandler_3e99bee971c5b7.service(Unknown Source) at $RequestHandler_3e99bee971c59f.service(Unknown Source) at org.apache.tapestry5.services.TapestryModule$HttpServletRequestHandlerTerminator.service(TapestryModule.java:253) at lithium.appcreator.web.common.services.AppSelectorServletRequestFilter.service(AppSelectorServletRequestFilter.java:66) at $HttpServletRequestHandler_3e99bee971c5a0.service(Unknown Source) at org.apache.tapestry5.upload.internal.services.MultipartServletRequestFilter.service(MultipartServletRequestFilter.java:44) at $HttpServletRequestHandler_3e99bee971c5a0.service(Unknown Source) at org.apache.tapestry5.internal.services.IgnoredPathsFilter.service(IgnoredPathsFilter.java:62) at $HttpServletRequestFilter_3e99bee971c59d.service(Unknown Source) at $HttpServletRequestHandler_3e99bee971c5a0.service(Unknown Source) at lithium.web2.services.request.LiaContextHttpServletRequestFilter.service(LiaContextHttpServletRequestFilter.java:64) at $HttpServletRequestHandler_3e99bee971c5a0.service(Unknown Source) at org.apache.tapestry5.services.TapestryModule$1.service(TapestryModule.java:852) at $HttpServletRequestHandler_3e99bee971c5a0.service(Unknown Source) at $HttpServletRequestHandler_3e99bee971c522.service(Unknown Source) at org.apache.tapestry5.TapestryFilter.doFilter(TapestryFilter.java:171) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.ContentSecurityPolicyHeaderFilter.doHttpFilter(ContentSecurityPolicyHeaderFilter.java:48) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.HttpRequestContextFilter.doHttpFilter(HttpRequestContextFilter.java:77) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.MaskedIpFilter.doHttpFilter(MaskedIpFilter.java:84) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.HashedIpFilter.doHttpFilter(HashedIpFilter.java:166) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.boards.servlet.pagecache.AnonymousPageCacheManager.doHttpFilter(AnonymousPageCacheManager.java:139) at lithium.boards.servlet.pagecache.AnonymousPageCacheFilter.doHttpFilter(AnonymousPageCacheFilter.java:44) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.boards.servlet.pagecache.PageCacheManager.doHttpFilter(PageCacheManager.java:403) at lithium.boards.servlet.pagecache.PageCacheFilter.doHttpFilter(PageCacheFilter.java:40) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.traffic.visitor.VisitorFilter.doHttpFilter(VisitorFilter.java:48) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.ratelimit.UserRateLimitFilter.doHttpFilter(UserRateLimitFilter.java:51) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.session.UserSessionFilter.doHttpFilter(UserSessionFilter.java:322) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.webui.http.filter.HystrixRequestContextFilter.doHttpFilter(HystrixRequestContextFilter.java:47) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.MultipartRequestHttpFilter.doHttpFilter(MultipartRequestHttpFilter.java:46) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.MimeFilter.doHttpFilter(MimeFilter.java:37) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.limit.StandardLimitPool.processRequest(StandardLimitPool.java:791) at lithium.servlet.limit.StandardLimitManager.processRequest(StandardLimitManager.java:192) at lithium.servlet.limit.LimitFilter.doHttpFilter(LimitFilter.java:71) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.RequestTransformFilter.doHttpFilter(RequestTransformFilter.java:72) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.SetHeaderValidationFilter.doHttpFilter(SetHeaderValidationFilter.java:52) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.SessionIdStripperFilter.doHttpFilter(SessionIdStripperFilter.java:44) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.AppTracedHttpFilter.doHttpFilter(AppTracedHttpFilter.java:112) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.redirect.SeoRedirectFilter.doHttpFilter(SeoRedirectFilter.java:72) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.metric.OTelWebVitalsFilter.doHttpFilter(OTelWebVitalsFilter.java:93) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.trace.OpenTelemetryAppTraceProvider.wrapServletRequest(OpenTelemetryAppTraceProvider.java:684) at lithium.trace.IsEnabledOpenTelemetryAppTraceProviderDecorator.wrapServletRequest(IsEnabledOpenTelemetryAppTraceProviderDecorator.java:209) at lithium.trace.StandardAppTraceManager.wrapServletRequest(StandardAppTraceManager.java:434) at lithium.trace.AppTraceFilter.doHttpFilter(AppTraceFilter.java:58) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.session.ReplicatedSessionFilter.doFilter(ReplicatedSessionFilter.java:57) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.rewrite.RewriteFilter.doHttpFilter(RewriteFilter.java:393) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.FacebookSignedRequestFilter.doHttpFilter(FacebookSignedRequestFilter.java:134) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.BlackboxFilter.doHttpFilter(BlackboxFilter.java:88) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.OperationsLoggingFilter.doHttpFilter(OperationsLoggingFilter.java:117) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.tracking.MailLinksTrackingFilter.doHttpFilter(MailLinksTrackingFilter.java:107) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.tracking.TrackingManager.doHttpFilter(TrackingManager.java:287) at lithium.servlet.tracking.TrackingFilter.doHttpFilter(TrackingFilter.java:25) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.boards.servlet.ClearStateFilter.doHttpFilter(ClearStateFilter.java:69) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.util.http.GenericFilter.doHttpFilter(GenericFilter.java:21) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.NotSecureSessionCookieFilter.doHttpFilter(NotSecureSessionCookieFilter.java:80) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.AccessCheckFilter.doHttpFilter(AccessCheckFilter.java:110) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.util.servlet.P3PHeaderFilter.doHttpFilter(P3PHeaderFilter.java:79) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.VanityHostnameRedirectFilter.doHttpFilter(VanityHostnameRedirectFilter.java:125) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.CanonicalIpFilter.doHttpFilter(CanonicalIpFilter.java:50) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.ForwardedHeadersFilter.doHttpFilter(ForwardedHeadersFilter.java:288) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.funnel.FunnelManager.doHttpFilter(FunnelManager.java:74) at lithium.servlet.funnel.FunnelFilter.doHttpFilter(FunnelFilter.java:41) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at lithium.util.http.DelegatingApplicationFilterProxy.doFilter(DelegatingApplicationFilterProxy.java:184) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.apps.main.container.filters.ApplicationSelectorFilter.doHttpFilter(ApplicationSelectorFilter.java:187) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.PutTomcatRequestinAttributeFilter.doFilter(PutTomcatRequestinAttributeFilter.java:60) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:57) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at lithium.servlet.ThreadNameFilter.doHttpFilter(ThreadNameFilter.java:49) at lithium.util.http.HttpFilter.doFilter(HttpFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:492) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:165) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104) at lithium.apps.main.webserver.Tomcat70Bootstrap$2.invoke(Tomcat70Bootstrap.java:383) at lithium.apps.main.webserver.Tomcat70Bootstrap$1.invoke(Tomcat70Bootstrap.java:336) at lithium.apps.main.webserver.SessionIdValidator.invoke(SessionIdValidator.java:107) at lithium.apps.main.webserver.ApplicationWebserverConfigurationValve.invoke(ApplicationWebserverConfigurationValve.java:69) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:190) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:654) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:317) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:748) Caused by: java.io.FileNotFoundException: /home/lithium/customer/nxp.prod/plugins.export/custom/nxp/nxp/prod/res/macros/theme-lib.common-functions.ftl (No such file or directory) at java.io.FileInputStream.open0(Native Method) at java.io.FileInputStream.open(FileInputStream.java:195) at java.io.FileInputStream.<init>(FileInputStream.java:138) at java.io.FileInputStream.<init>(FileInputStream.java:93) at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:90) at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:188) at freemarker.cache.URLTemplateSource.close(URLTemplateSource.java:126) at freemarker.cache.URLTemplateLoader.closeTemplateSource(URLTemplateLoader.java:60) at freemarker.cache.MultiTemplateLoader$MultiSource.close(MultiTemplateLoader.java:147) at freemarker.cache.MultiTemplateLoader.closeTemplateSource(MultiTemplateLoader.java:107) at freemarker.cache.TemplateCache.getTemplateInternal(TemplateCache.java:459) at freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:292) at freemarker.template.Configuration.getTemplate(Configuration.java:2518) at freemarker.core.Environment.getTemplateForInclusion(Environment.java:2466) at freemarker.core.Include.accept(Include.java:162) ... 442 more
