Yocto fsl-initramfs 4.1.15 mfgtool partition fail
868 次查看
jiujinhong
Hi, i have built yocto 4.1.15 fsl-initramfs image for mfgtool, but sfdisk partition table display miss order, Partition table entries are not in disk order. Can you give some advice?  We use mfgtool V2.
20180808_09:37:15]U-Boot 2015.04-imx_v2015.04_4.1.15_1.0.0_ga+g6ea61c3 (Aug 03 2018 - 14:33:19)
20180808_09:37:15]
20180808_09:37:15]CPU:   Freescale i.MX6D rev1.5 at 792 MHz
20180808_09:37:15]CPU:   Temperature 58 C
20180808_09:37:15]Reset cause: POR
20180808_09:37:15]Board: MX6-SabreSD
20180808_09:37:15]I2C:   ready
20180808_09:37:15]DRAM:  2 GiB
20180808_09:37:15]Using default environment
20180808_09:37:15]
20180808_09:37:15]In:    serial
20180808_09:37:15]Out:   serial
20180808_09:37:15]Err:   serial
20180808_09:37:15]Boot from USB for mfgtools
20180808_09:37:15]Use default environment for                              mfgtools
20180808_09:37:15]Run bootcmd_mfg: run mfgtool_args;bootz 0x14000000 0x16000000 0x18000000;
20180808_09:37:15]Hit any key to stop autoboot:  0
20180808_09:37:15]Kernel image @ 0x14000000 [ 0x000000 - 0x642c70 ]
20180808_09:37:15]## Loading init Ramdisk from Legacy Image at 16000000 ...
20180808_09:37:15]   Image Name:   fsl-image-mfgtool-initramfs-imx6
20180808_09:37:15]   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
20180808_09:37:15]   Data Size:    7802080 Bytes = 7.4 MiB
20180808_09:37:15]   Load Address: 00000000
20180808_09:37:15]   Entry Point:  00000000
20180808_09:37:15]   Verifying Checksum ... OK
20180808_09:37:15]## Flattened Device Tree blob at 18000000
20180808_09:37:15]   Booting using the fdt blob at 0x18000000
20180808_09:37:15]   Using Device Tree in place at 18000000, end 1800df75
20180808_09:37:15]No PMIC found!
20180808_09:37:15]
20180808_09:37:15]Starting kernel ...
20180808_09:37:15]
20180808_09:37:17]Booting Linux on physical CPU 0x0
20180808_09:37:17]Linux version 4.1.29-fslc+g59b38c3 (jiujin@jiujin-linux) (gcc version 5.3.0 (GCC) ) #3 SMP PREEMPT Mon Aug 6 10:22:19 CST 2018
20180808_09:37:17]CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
20180808_09:37:17]CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
20180808_09:37:17]Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
20180808_09:37:17]Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
20180808_09:37:17]Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
20180808_09:37:17]Memory policy: Data cache writealloc
20180808_09:37:17]PERCPU: Embedded 12 pages/cpu @ee718000 s16908 r8192 d24052 u49152
20180808_09:37:17]Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520720
20180808_09:37:17]Kernel command line: console=ttymxc3,115200 rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber= enable_wait_mode=off
20180808_09:37:17]PID hash table entries: 4096 (order: 2, 16384 bytes)
20180808_09:37:17]Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
20180808_09:37:17]Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
20180808_09:37:17]Memory: 1730432K/2097152K available (8240K kernel code, 432K rwdata, 2928K rodata, 428K init, 450K bss, 39040K reserved, 327680K cma-reserved, 270336K highmem)
20180808_09:37:17]Virtual kernel memory layout:
20180808_09:37:17]    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
20180808_09:37:17]    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
20180808_09:37:17]    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
20180808_09:37:17]    lowmem  : 0x80000000 - 0xef800000   (1784 MB)
20180808_09:37:17]    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
20180808_09:37:17]    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
20180808_09:37:17]      .text : 0x80008000 - 0x80af04f4   (11170 kB)
20180808_09:37:17]      .init : 0x80af1000 - 0x80b5c000   ( 428 kB)
20180808_09:37:17]      .data : 0x80b5c000 - 0x80bc82e0   ( 433 kB)
20180808_09:37:17]       .bss : 0x80bcb000 - 0x80c3b8c0   ( 451 kB)
20180808_09:37:17]SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
20180808_09:37:17]Preemptible hierarchical RCU implementation.
20180808_09:37:17]        Additional per-CPU info printed with stalls.
20180808_09:37:17]        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
20180808_09:37:17]RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
20180808_09:37:17]NR_IRQS:16 nr_irqs:16 16
20180808_09:37:17]L2C-310 erratum 769419 enabled
20180808_09:37:17]L2C-310 enabling early BRESP for Cortex-A9
20180808_09:37:17]L2C-310 full line of zeros enabled for Cortex-A9
20180808_09:37:17]L2C-310 ID prefetch enabled, offset 16 lines
20180808_09:37:17]L2C-310 dynamic clock gating enabled, standby mode enabled
20180808_09:37:17]L2C-310 cache controller enabled, 16 ways, 1024 kB
20180808_09:37:17]L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76070001
20180808_09:37:17]mxc_clocksource_init 3000000
20180808_09:37:17]Switching to timer-based delay loop, resolution 333ns
20180808_09:37:17]sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
20180808_09:37:17]clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
20180808_09:37:17]Console: colour dummy device 80x30
20180808_09:37:17]Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
20180808_09:37:17]pid_max: default: 32768 minimum: 301
20180808_09:37:17]Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
20180808_09:37:17]Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
20180808_09:37:17]CPU: Testing write buffer coherency: ok
20180808_09:37:17]CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
20180808_09:37:17]Setting up static identity map for 0x10008280 - 0x100082d8
20180808_09:37:17]CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
20180808_09:37:17]Brought up 2 CPUs
20180808_09:37:17]SMP: Total of 2 processors activated (12.00 BogoMIPS).
20180808_09:37:17]CPU: All CPU(s) started in SVC mode.
20180808_09:37:17]devtmpfs: initialized
20180808_09:37:17]VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
20180808_09:37:17]clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
20180808_09:37:17]pinctrl core: initialized pinctrl subsystem
20180808_09:37:17]NET: Registered protocol family 16
20180808_09:37:17]DMA: preallocated 256 KiB pool for atomic coherent allocations
20180808_09:37:17]cpuidle: using governor ladder
20180808_09:37:17]cpuidle: using governor menu
20180808_09:37:17]CPU identified as i.MX6Q, silicon rev 1.5
20180808_09:37:17]tps usbcharg probe successfully.
20180808_09:37:17]hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
20180808_09:37:17]hw-breakpoint: maximum watchpoint size is 4 bytes.
20180808_09:37:17]imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/ecspi1grp
20180808_09:37:17]imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/ipu1grp
20180808_09:37:17]imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
20180808_09:37:17]mxs-dma 110000.dma-apbh: initialized
20180808_09:37:17]reg-fixed-voltage regulators:regulator@0: Failed to resolve vin-supply for usb_otg_vbus
20180808_09:37:17]SCSI subsystem initialized
20180808_09:37:17]usbcore: registered new interface driver usbfs
20180808_09:37:17]usbcore: registered new interface driver hub
20180808_09:37:17]usbcore: registered new device driver usb
20180808_09:37:17]2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
20180808_09:37:17]2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
20180808_09:37:17]i2c i2c-0: IMX I2C adapter registered
20180808_09:37:17]i2c i2c-0: can't use DMA
20180808_09:37:17]i2c i2c-1: of_i2c: modalias failure on /soc/aips-bus@02100000/i2c@021a4000/max11801@48
20180808_09:37:17]i2c i2c-1: IMX I2C adapter registered
20180808_09:37:17]i2c i2c-1: can't use DMA
20180808_09:37:17]i2c i2c-2: IMX I2C adapter registered
20180808_09:37:17]i2c i2c-2: can't use DMA
20180808_09:37:17]Linux video capture interface: v2.00
20180808_09:37:17]pps_core: LinuxPPS API ver. 1 registered
20180808_09:37:17]pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
20180808_09:37:17]PTP clock support registered
20180808_09:37:17]imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
20180808_09:37:17]imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
20180808_09:37:17]mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
20180808_09:37:17]mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
20180808_09:37:17]MIPI CSI2 driver module loaded
20180808_09:37:17]Advanced Linux Sound Architecture Driver Initialized.
20180808_09:37:17]Bluetooth: Core ver 2.20
20180808_09:37:17]NET: Registered protocol family 31
20180808_09:37:17]Bluetooth: HCI device and connection manager initialized
20180808_09:37:17]Bluetooth: HCI socket layer initialized
20180808_09:37:17]Bluetooth: L2CAP socket layer initialized
20180808_09:37:17]Bluetooth: SCO socket layer initialized
20180808_09:37:17]Switched to clocksource mxc_timer1
20180808_09:37:17]NET: Registered protocol family 2
20180808_09:37:17]TCP established hash table entries: 16384 (order: 4, 65536 bytes)
20180808_09:37:17]TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
20180808_09:37:17]TCP: Hash tables configured (established 16384 bind 16384)
20180808_09:37:17]UDP hash table entries: 1024 (order: 3, 32768 bytes)
20180808_09:37:17]UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
20180808_09:37:17]RPC: Registered named UNIX socket transport module.
20180808_09:37:17]RPC: Registered udp transport module.
20180808_09:37:17]RPC: Registered tcp transport module.
20180808_09:37:17]RPC: Registered tcp NFSv4.1 backchannel transport module.
20180808_09:37:17]Trying to unpack rootfs image as initramfs...
20180808_09:37:17]Freeing initrd memory: 7620K (86000000 - 86771000)
20180808_09:37:17]CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
20180808_09:37:17]hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
20180808_09:37:17]imx rpmsg driver is registered.
20180808_09:37:17]Bus freq driver module loaded
20180808_09:37:17]futex hash table entries: 512 (order: 3, 32768 bytes)
20180808_09:37:17]VFS: Disk quotas dquot_6.6.0
20180808_09:37:17]VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
20180808_09:37:17]NFS: Registering the id_resolver key type
20180808_09:37:17]Key type id_resolver registered
20180808_09:37:17]Key type id_legacy registered
20180808_09:37:17]jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
20180808_09:37:17]fuse init (API version 7.23)
20180808_09:37:17]bounce: pool size: 64 pages
20180808_09:37:17]io scheduler noop registered
20180808_09:37:17]io scheduler deadline registered
20180808_09:37:17]io scheduler cfq registered (default)
20180808_09:37:17]imx-weim 21b8000.weim: Driver registered.
20180808_09:37:17]backlight supply power not found, using dummy regulator
20180808_09:37:17]mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
20180808_09:37:17]MIPI DSI driver module loaded
20180808_09:37:17]mxc_sdc_fb fb@0: registered mxc display driver ldb
20180808_09:37:17]imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
20180808_09:37:17]Console: switching to colour frame buffer device 128x48
20180808_09:37:17]mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
20180808_09:37:17]fbcvt: 1920x1080@60: CVT Name - 2.073M9
20180808_09:37:17]mxc_sdc_fb fb@1: registered mxc display driver hdmi
20180808_09:37:17]mxc_sdc_fb fb@2: registered mxc display driver lcd
20180808_09:37:17]mxc_sdc_fb fb@2: ipu0-di0 already in use
20180808_09:37:17]mxc_sdc_fb: probe of fb@2 failed with error -16
20180808_09:37:17]mxc_sdc_fb fb@3: registered mxc display driver ldb
20180808_09:37:17]imx-sdma 20ec000.sdma: no iram assigned, using external mem
20180808_09:37:17]imx-sdma 20ec000.sdma: no event needs to be remapped
20180808_09:37:17]imx-sdma 20ec000.sdma: loaded firmware 3.3
20180808_09:37:17]imx-sdma 20ec000.sdma: initialized
20180808_09:37:17]pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
20180808_09:37:17]pfuze100-regulator 0-0008: FAB: 0, FIN: 0
20180808_09:37:17]pfuze100-regulator 0-0008: pfuze100 found.
20180808_09:37:17]usb_otg_vbus: supplied by SWBST
20180808_09:37:17]usb_h1_vbus: supplied by SWBST
20180808_09:37:17]2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 25, base_baud = 5000000) is a IMX
20180808_09:37:17]21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 300, base_baud = 5000000) is a IMX
20180808_09:37:17]console [ttymxc3] enabled
20180808_09:37:17]imx sema4 driver is registered.
20180808_09:37:17][drm] Initialized drm 1.1.0 20060810
20180808_09:37:17][drm] Initialized vivante 1.0.0 20120216 on minor 0
20180808_09:37:17]brd: module loaded
20180808_09:37:17]loop: module loaded
20180808_09:37:17]ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
20180808_09:37:17]ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
20180808_09:37:17]ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
20180808_09:37:17]ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
20180808_09:37:17]ahci-imx 2200000.sata: failed to reset phy: -110
20180808_09:37:17]ahci-imx: probe of 2200000.sata failed with error -110
20180808_09:37:17]m25p80 spi0.0: unrecognized JEDEC id bytes: 00,  0,  0
20180808_09:37:17]spi_imx 2008000.ecspi: probed
20180808_09:37:17]CAN device driver interface
20180808_09:37:17]2188000.ethernet supply phy not found, using dummy regulator
20180808_09:37:18]pps pps0: new PPS source ptp0
20180808_09:37:18]fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
20180808_09:37:18]fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: c6:b2:46:b4:c3:ee
20180808_09:37:18]libphy: fec_enet_mii_bus: probed
20180808_09:37:18]fec 2188000.ethernet eth0: registered PHC device 0
20180808_09:37:18]ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
20180808_09:37:18]ehci-mxc: Freescale On-Chip EHCI Host driver
20180808_09:37:18]usbcore: registered new interface driver usb-storage
20180808_09:37:18]usbcore: registered new interface driver usb_ehset_test
20180808_09:37:18]2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
20180808_09:37:18]ci_hdrc ci_hdrc.1: EHCI Host Controller
20180808_09:37:18]ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
20180808_09:37:18]ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
20180808_09:37:18]hub 1-0:1.0: USB hub found
20180808_09:37:18]hub 1-0:1.0: 1 port detected
20180808_09:37:18]Mass Storage Function, version: 2009/09/11
20180808_09:37:18]LUN: removable file: (no medium)
20180808_09:37:18]LUN: removable read only file: /fat
20180808_09:37:18]Number of LUNs=1
20180808_09:37:18]g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
20180808_09:37:18]g_mass_storage gadget: g_mass_storage ready
20180808_09:37:18]mousedev: PS/2 mouse device common for all mice
20180808_09:37:18]egalax_ts 1-0004: Failed to read firmware version
20180808_09:37:18]egalax_ts: probe of 1-0004 failed with error -5
20180808_09:37:18]egalax_ts 2-0004: Failed to read firmware version
20180808_09:37:18]egalax_ts: probe of 2-0004 failed with error -11
20180808_09:37:18]snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
20180808_09:37:18]i2c /dev entries driver
20180808_09:37:18]IR NEC protocol handler initialized
20180808_09:37:18]IR RC5(x/sz) protocol handler initialized
20180808_09:37:18]IR RC6 protocol handler initialized
20180808_09:37:18]IR JVC protocol handler initialized
20180808_09:37:18]IR Sony protocol handler initialized
20180808_09:37:18]IR SANYO protocol handler initialized
20180808_09:37:18]IR Sharp protocol handler initialized
20180808_09:37:18]IR MCE Keyboard/mouse protocol handler initialized
20180808_09:37:18]IR XMP protocol handler initialized
20180808_09:37:18]mxc_v4l2_output v4l2_out: V4L2 device registered as video16
20180808_09:37:18]mxc_v4l2_output v4l2_out: V4L2 device registered as video17
20180808_09:37:18]mxc_v4l2_output v4l2_out: V4L2 device registered as video18
20180808_09:37:18]mxc_v4l2_output v4l2_out: V4L2 device registered as video19
20180808_09:37:18]mxc_v4l2_output v4l2_out: V4L2 device registered as video20
20180808_09:37:18]mag3110 2-000e: check mag3110 chip ID
20180808_09:37:18]mag3110 2-000e: read chip ID 0xfffffff5 is not equal to 0xc4!
20180808_09:37:18]mag3110: probe of 2-000e failed with error -22
20180808_09:37:18]mma8451 0-001c: read chip ID 0x1 is not equal to 0x1a or 0x2a!
20180808_09:37:18]mma8451: probe of 0-001c failed with error -22
20180808_09:37:18]imx2-wdt 20c0000.wdog: use WDOG_B to reboot.
20180808_09:37:18]imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
20180808_09:37:18]Bluetooth: HCI UART driver ver 2.3
20180808_09:37:18]Bluetooth: HCI UART protocol H4 registered
20180808_09:37:18]Bluetooth: HCI UART protocol BCSP registered
20180808_09:37:18]Bluetooth: HCI UART protocol ATH3K registered
20180808_09:37:18]usbcore: registered new interface driver bcm203x
20180808_09:37:18]usbcore: registered new interface driver btusb
20180808_09:37:18]usbcore: registered new interface driver ath3k
20180808_09:37:18]sdhci: Secure Digital Host Controller Interface driver
20180808_09:37:18]sdhci: Copyright(c) Pierre Ossman
20180808_09:37:18]sdhci-pltfm: SDHCI platform and OF driver helper
20180808_09:37:18]/soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
20180808_09:37:18]sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
20180808_09:37:18]sdhci-esdhc-imx 2194000.usdhc: Got WP GPIO
20180808_09:37:18]sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
20180808_09:37:18]sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
20180808_09:37:18]mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
20180808_09:37:18]/soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
20180808_09:37:18]sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
20180808_09:37:18]sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
20180808_09:37:18]sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
20180808_09:37:18]sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
20180808_09:37:18]usb 1-1: new high-speed USB device number 2 using ci_hdrc
20180808_09:37:18]mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
20180808_09:37:18]/soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
20180808_09:37:18]g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
20180808_09:37:18]sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
20180808_09:37:18]sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
20180808_09:37:18]mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
20180808_09:37:18]mxc_vpu 2040000.vpu_fsl: VPU initialized
20180808_09:37:18]mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
20180808_09:37:18]mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
20180808_09:37:18]caam 2100000.caam: Entropy delay = 3200
20180808_09:37:18]hub 1-1:1.0: USB hub found
20180808_09:37:18]hub 1-1:1.0: 4 ports detected
20180808_09:37:18]caam 2100000.caam: Instantiated RNG4 SH0
20180808_09:37:18]mmc3: MAN_BKOPS_EN bit is not set
20180808_09:37:18]mmc3: new DDR MMC card at address 0001
20180808_09:37:18]mmcblk3: mmc3:0001 032G34 29.1 GiB
20180808_09:37:18]mmcblk3boot0: mmc3:0001 032G34 partition 1 8.00 MiB
20180808_09:37:18]caam 2100000.caam: Instantiated RNG4 SH1
20180808_09:37:18]caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
20180808_09:37:18]caam 2100000.caam: job rings = 2, qi = 0
20180808_09:37:18]mmcblk3boot1: mmc3:0001 032G34 partition 2 8.00 MiB
20180808_09:37:18]mmcblk3rpmb: mmc3:0001 032G34 partition 3 4.00 MiB
20180808_09:37:18] mmcblk3: p1 p2 p3 < p5 p6 p7 > p4
20180808_09:37:18]caam algorithms registered in /proc/crypto
20180808_09:37:18]caam_jr 2101000.jr0: registering rng-caam
20180808_09:37:18]platform caam_sm: blkkey_ex: 4 keystore units available
20180808_09:37:18]platform caam_sm: 64-bit clear key:
20180808_09:37:18]platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
20180808_09:37:18]platform caam_sm: 64-bit black key:
20180808_09:37:18]platform caam_sm: [0000] af d0 cd d0 a1 49 d0 54
20180808_09:37:18]platform caam_sm: [0008] d1 90 65 f1 96 42 72 6e
20180808_09:37:18]platform caam_sm: 128-bit clear key:
20180808_09:37:18]platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
20180808_09:37:18]platform caam_sm: 128-bit black key:
20180808_09:37:18]platform caam_sm: [0000] df ba 8a cf 96 e4 76 cd
20180808_09:37:18]platform caam_sm: [0008] 8c 56 9b 55 b7 c4 19 9f
20180808_09:37:18]platform caam_sm: 192-bit clear key:
20180808_09:37:18]platform caam_sm: [0016] 10 11 12 13 14 15 16 17
20180808_09:37:18]platform caam_sm: 192-bit black key:
20180808_09:37:18]platform caam_sm: [0000] a3 58 55 41 ef d6 f8 f8
20180808_09:37:18]platform caam_sm: [0008] fe 1d a3 44 30 d4 a7 ca
20180808_09:37:18]platform caam_sm: [0016] 3b db 57 d1 3b 2e 39 0f
20180808_09:37:18]platform caam_sm: [0024] 7f 3e 6e 9b 17 38 0a 6c
20180808_09:37:18]platform caam_sm: 256-bit clear key:
20180808_09:37:18]platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
20180808_09:37:18]platform caam_sm: 256-bit black key:
20180808_09:37:18]platform caam_sm: [0000] fa 4f 5f e7 75 bf 45 af
20180808_09:37:18]platform caam_sm: [0008] 59 f0 4a b4 64 d9 48 9f
20180808_09:37:18]platform caam_sm: [0016] 0f 17 76 c3 95 c5 c0 5a
20180808_09:37:18]platform caam_sm: [0024] bf 24 6b 87 62 20 4f 88
20180808_09:37:18]platform caam_sm: 64-bit unwritten blob:
20180808_09:37:18]platform caam_sm: [0000] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0008] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0016] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0024] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0032] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0040] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0048] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0056] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0064] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0072] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0080] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: [0088] 00 00 00 00 00 00 00 00
20180808_09:37:18]platform caam_sm: 128-bit unwritten blob:
20180808_09:37:19]platform caam_sm: [0072] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0080] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0088] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: 196-bit unwritten blob:
20180808_09:37:19]platform caam_sm: [0000] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0008] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0016] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0024] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0032] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0040] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0048] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0056] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: [0064] 00 00 00 00 00 00 00 00
20180808_09:37:19]platform caam_sm: 256-bit unwritten blob:
20180808_09:37:19]platform caam_sm: 64-bit black key in blob:
20180808_09:37:19]platform caam_sm: [0000] 5a 78 84 9c ec d6 6e c7
20180808_09:37:19]platform caam_sm: [0008] 98 c1 c8 07 98 e3 2a 04
20180808_09:37:19]platform caam_sm: [0016] bc 5e 60 5e 09 4f ce ed
20180808_09:37:19]platform caam_sm: [0024] a1 a4 a2 20 0b ce 39 7c
20180808_09:37:19]platform caam_sm: [0032] e5 60 dd e2 67 b3 a7 e6
20180808_09:37:19]platform caam_sm: [0040] 12 06 76 57 58 7a f4 35
20180808_09:37:19]platform caam_sm: [0048] 9c 92 34 26 8b 89 f5 0a
20180808_09:37:19]platform caam_sm: 128-bit black key in blob:
20180808_09:37:19]platform caam_sm: [0000] 16 6f 85 83 ad f5 1f e8
20180808_09:37:19]platform caam_sm: [0008] 7f ab f9 41 65 58 51 10
20180808_09:37:19]platform caam_sm: [0016] b8 52 97 42 8e d8 1e 7a
20180808_09:37:19]platform caam_sm: [0024] fe bd fd 57 09 57 4b 9c
20180808_09:37:19]platform caam_sm: [0032] b3 48 15 18 f7 2e 0b 61
20180808_09:37:19]platform caam_sm: [0040] 07 6f 96 04 50 ca 84 af
20180808_09:37:19]platform caam_sm: [0048] 42 30 77 29 be 0b ab 51
20180808_09:37:19]platform caam_sm: [0056] b2 93 6e 68 32 80 4e a4
20180808_09:37:19]platform caam_sm: 192-bit black key in blob:
20180808_09:37:19]platform caam_sm: [0000] db 35 c2 5b 1a 34 cb 06
20180808_09:37:19]platform caam_sm: [0008] 9e 68 f0 cb 84 e3 7b a7
20180808_09:37:19]platform caam_sm: [0016] cc a8 47 af d3 fe 4c 11
20180808_09:37:19]platform caam_sm: [0024] 4c bc b6 7e 86 24 9a 4a
20180808_09:37:19]platform caam_sm: [0032] 84 9d 0e 85 69 ce 44 9a
20180808_09:37:19]platform caam_sm: [0040] 49 96 58 09 68 8e 5b 74
20180808_09:37:19]platform caam_sm: [0048] f0 89 c4 d6 d0 ed f4 c7
20180808_09:37:19]platform caam_sm: [0056] 38 ae e7 b5 f8 4c 50 8e
20180808_09:37:19]platform caam_sm: [0064] 32 4e af b0 eb a3 a5 7d
20180808_09:37:19]platform caam_sm: 256-bit black key in blob:
20180808_09:37:19]platform caam_sm: [0000] fc 06 19 af 8b a0 27 7b
20180808_09:37:19]platform caam_sm: [0008] c8 a1 ee e2 96 62 b9 55
20180808_09:37:19]platform caam_sm: [0016] 54 0c 17 05 b4 1b a2 d5
20180808_09:37:19]platform caam_sm: [0024] bc a1 c0 95 63 eb ff 4d
20180808_09:37:19]platform caam_sm: [0032] 8e 08 1b 73 db 63 d0 e4
20180808_09:37:19]platform caam_sm: [0040] 88 23 17 2b 79 50 24 1c
20180808_09:37:19]platform caam_sm: [0048] 4f 84 b0 f2 25 de 0c 47
20180808_09:37:19]platform caam_sm: [0056] b2 5e ff bc 7b 7f 32 fe
20180808_09:37:19]platform caam_sm: [0064] b8 96 56 ef 3a 97 44 24
20180808_09:37:19]platform caam_sm: [0072] fc 6c 73 4b fe 8c 79 6b
20180808_09:37:19]platform caam_sm: restored 64-bit black key:
20180808_09:37:19]platform caam_sm: [0000] 35 45 b8 ae ec c1 c0 06
20180808_09:37:19]platform caam_sm: [0008] e4 bb 61 64 e9 fe a4 f7
20180808_09:37:19]platform caam_sm: restored 128-bit black key:
20180808_09:37:19]platform caam_sm: [0000] df ba 8a cf 96 e4 76 cd
20180808_09:37:19]platform caam_sm: [0008] 8c 56 9b 55 b7 c4 19 9f
20180808_09:37:19]platform caam_sm: restored 192-bit black key:
20180808_09:37:19]platform caam_sm: [0000] a3 58 55 41 ef d6 f8 f8
20180808_09:37:19]platform caam_sm: [0008] fe 1d a3 44 30 d4 a7 ca
20180808_09:37:19]platform caam_sm: [0016] 7a 7a d4 df cc e2 b1 8c
20180808_09:37:19]platform caam_sm: [0024] b1 63 c0 2a 97 ad 16 27
20180808_09:37:19]platform caam_sm: restored 256-bit black key:
20180808_09:37:19]platform caam_sm: [0000] fa 4f 5f e7 75 bf 45 af
20180808_09:37:19]platform caam_sm: [0008] 59 f0 4a b4 64 d9 48 9f
20180808_09:37:19]platform caam_sm: [0016] 0f 17 76 c3 95 c5 c0 5a
20180808_09:37:19]platform caam_sm: [0024] bf 24 6b 87 62 20 4f 88
20180808_09:37:19]snvs-secvio 20cc000.caam-snvs: can't get snvs clock
20180808_09:37:19]snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
20180808_09:37:19]usbcore: registered new interface driver usbhid
20180808_09:37:19]usbhid: USB HID core driver
20180808_09:37:19]wm8962 0-001a: Failed to read ID register
20180808_09:37:19]wm8962: probe of 0-001a failed with error -5
20180808_09:37:19]fsl-asrc 2034000.asrc: driver registered
20180808_09:37:19]imx-wm8962 sound: failed to find codec platform device
20180808_09:37:19]imx-wm8962: probe of sound failed with error -22
20180808_09:37:19]imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
20180808_09:37:19]NET: Registered protocol family 26
20180808_09:37:19]NET: Registered protocol family 10
20180808_09:37:19]sit: IPv6 over IPv4 tunneling driver
20180808_09:37:19]NET: Registered protocol family 17
20180808_09:37:19]can: controller area network core (rev 20120528 abi 9)
20180808_09:37:19]NET: Registered protocol family 29
20180808_09:37:19]can: raw protocol (rev 20120528)
20180808_09:37:19]can: broadcast manager protocol (rev 20120528 t)
20180808_09:37:19]can: netlink gateway (rev 20130117) max_hops=1
20180808_09:37:19]Bluetooth: RFCOMM TTY layer initialized
20180808_09:37:19]Bluetooth: RFCOMM socket layer initialized
20180808_09:37:19]Bluetooth: RFCOMM ver 1.11
20180808_09:37:19]Bluetooth: BNEP (Ethernet Emulation) ver 1.3
20180808_09:37:19]Bluetooth: BNEP filters: protocol multicast
20180808_09:37:19]Bluetooth: BNEP socket layer initialized
20180808_09:37:19]Bluetooth: HIDP (Human Interface Emulation) ver 1.2
20180808_09:37:19]Bluetooth: HIDP socket layer initialized
20180808_09:37:19]8021q: 802.1Q VLAN Support v1.8
20180808_09:37:19]Key type dns_resolver registered
20180808_09:37:19]dhd_module_init in
20180808_09:37:19]input: gpio-keys as /devices/soc0/gpio-keys/input/input2
20180808_09:37:19]snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
20180808_09:37:19]usb_otg_vbus: disabling
20180808_09:37:19]wm8962-supply: disabling
20180808_09:37:19]SW4: disabling
20180808_09:37:19]VGEN1: disabling
20180808_09:37:19]VGEN2: disabling
20180808_09:37:19]VGEN3: disabling
20180808_09:37:19]ALSA device list:
20180808_09:37:19]  #0: imx-hdmi-soc
20180808_09:37:19]Freeing unused kernel memory: 428K (80af1000 - 80b5c000)
20180808_09:37:21]Starting UTP
20180808_09:37:21]uuc 0.5 [built Aug  6 2018 10:23:52]
20180808_09:37:21]UTP: Waiting for device to appear
20180808_09:37:21]UTP: file/device node /dev/utp already exists
20180808_09:37:21]cpu_id is 0
20180808_09:37:21]UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=1536 count=16'
20180808_09:37:21]UTP: executing "dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=1536 count=16"
20180808_09:37:21]16+0 records in
20180808_09:37:21]16+0 records out
20180808_09:37:21]8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0108037 s, 758 kB/s
20180808_09:37:21]UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=1536 count=16.
20180808_09:37:21]utp_poll: pass returned.
20180808_09:37:21]UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=4096 count=2'
20180808_09:37:21]UTP: executing "dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=4096 count=2"
20180808_09:37:21]2+0 records in
20180808_09:37:21]2+0 records out
20180808_09:37:21]1024 bytes (1.0 kB, 1.0 KiB) copied, 0.009759 s, 105 kB/s
20180808_09:37:21]UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk3 bs=512 seek=4096 count=2.
20180808_09:37:21]UTP: received command 'send'
20180808_09:37:21]UTP: sending Success to kernel for command send.
20180808_09:37:21]UTP: received command '$ echo 0 > /sys/block/mmcblk3boot0/force_ro'
20180808_09:37:21]UTP: executing "echo 0 > /sys/block/mmcblk3boot0/force_ro"
20180808_09:37:21]UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk3boot0/force_ro.
20180808_09:37:21]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3boot0 bs=512 seek=2'
20180808_09:37:21]UTP: executing "dd if=$FILE of=/dev/mmcblk3boot0 bs=512 seek=2"
20180808_09:37:22]798+0 records in
20180808_09:37:22]798+0 records out
20180808_09:37:22]408576 bytes (409 kB, 399 KiB) copied, 0.130122 s, 3.1 MB/s
20180808_09:37:22]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3boot0 bs=512 seek=2.
20180808_09:37:22]utp_poll: pass returned.
20180808_09:37:22]UTP: received command '$ echo 1 > /sys/block/mmcblk3boot0/force_ro'
20180808_09:37:22]UTP: executing "echo 1 > /sys/block/mmcblk3boot0/force_ro"
20180808_09:37:22]UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk3boot0/force_ro.
20180808_09:37:22]UTP: received command '$ echo 0 > /sys/block/mmcblk3boot1/force_ro'
20180808_09:37:22]UTP: executing "echo 0 > /sys/block/mmcblk3boot1/force_ro"
20180808_09:37:22]UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk3boot1/force_ro.
20180808_09:37:22]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3boot1 bs=512 seek=2'
20180808_09:37:22]UTP: executing "dd if=$FILE of=/dev/mmcblk3boot1 bs=512 seek=2"
20180808_09:37:22]408576 bytes (409 kB, 399 KiB) copied, 0.131721 s, 3.1 MB/s
20180808_09:37:22]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3boot1 bs=512 seek=2.
20180808_09:37:22]UTP: received command '$ echo 1 > /sys/block/mmcblk3boot1/force_ro'
20180808_09:37:22]UTP: executing "echo 1 > /sys/block/mmcblk3boot1/force_ro"
20180808_09:37:22]UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk3boot1/force_ro.
20180808_09:37:23]utp_poll: pass returned.
20180808_09:37:23]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=2'
20180808_09:37:23]UTP: executing "dd if=$FILE of=/dev/mmcblk3 bs=512 seek=2"
20180808_09:37:23]798+0 records in
20180808_09:37:23]798+0 records out
20180808_09:37:23]408576 bytes (409 kB, 399 KiB) copied, 0.0756047 s, 5.4 MB/s
20180808_09:37:23]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=2.
20180808_09:37:23]UTP: received command '$ mmc bootpart enable 1 1 /dev/mmcblk3'
20180808_09:37:23]UTP: executing "mmc bootpart enable 1 1 /dev/mmcblk3"
20180808_09:37:23]UTP: sending Success to kernel for command $ mmc bootpart enable 1 1 /dev/mmcblk3.
20180808_09:37:23]UTP: received command '$ mmc writeprotect get /dev/mmcblk3'
20180808_09:37:23]UTP: executing "mmc writeprotect get /dev/mmcblk3"
20180808_09:37:23]Boot write protection status registers [BOOT_WP_STATUS]: 0x00
20180808_09:37:23]Boot Area Write protection [BOOT_WP]: 0x00
20180808_09:37:23] Power ro locking: possible
20180808_09:37:23] Permanent ro locking: possible
20180808_09:37:23] ro lock status: not locked
20180808_09:37:23]UTP: sending Success to kernel for command $ mmc writeprotect get /dev/mmcblk3.
20180808_09:37:23]UTP: received command 'send'
20180808_09:37:23]UTP: sending Success to kernel for command send.
20180808_09:37:23]UTP: received command '$ tar xf $FILE '
20180808_09:37:23]UTP: executing "tar xf $FILE "
20180808_09:37:23]UTP: sending Success to kernel for command $ tar xf $FILE .
20180808_09:37:24]utp_poll: pass returned.
20180808_09:37:24]UTP: received command '$ sh mksdcard-android.sh /dev/mmcblk3'
20180808_09:37:24]UTP: executing "sh mksdcard-android.sh /dev/mmcblk3"
20180808_09:37:24]1+0 records in
20180808_09:37:24]1+0 records out
20180808_09:37:24]1024 bytes (1.0 kB, 1.0 KiB) copied, 0.009236 s, 111 kB/s
20180808_09:37:24]Checking that no-one is using thirandom: sfdisk urandom read with 37 bits of entropy available
20180808_09:37:24]s disk right now ... OK
20180808_09:37:24]
20180808_09:37:24]Disk /dev/mmcblk3: 29.1 GiB, 31268536320 bytes, 61071360 sectors
20180808_09:37:24]Units: sectors of 1 * 512 =  mmcblk3: p1 p2 p3 < p5 p6 p7 > p4
20180808_09:37:24]512 bytes
20180808_09:37:24]Sector size (logical/physical): 512 bytes / 512 bytes
20180808_09:37:24]I/O size (minimum/optimal): 512 bytes / 512 bytes
20180808_09:37:24]
20180808_09:37:24]>>> Created a new DOS disklabel with disk identifier 0x6c9d2afd.
20180808_09:37:24]Created a new partition 1 of type 'Linux mmcblk3: p1 p2 p3 < p5 p6 p7 > p4
20180808_09:37:24]' and of size 40 MiB.
20180808_09:37:24]/dev/mmcblk3p2: Created a new partition 2 of type 'Linux' and of size 32 MiB.
20180808_09:37:24]/dev/mmcblk3p3: Created a new partition 3 of type 'Extended' and of size 3.4 GiB.
20180808_09:37:24]/dev/mmcblk3p4: Created a new partition 4 of type 'Linux' and of size 25.7 GiB.
20180808_09:37:24]/dev/mmcblk3p5: Created a new partition 5 of type 'Linux' and of size 1.8 GiB.
20180808_09:37:24]/dev/mmcblk3p6: Created a new partition 6 of type 'Linux' and of size 512 MiB.
20180808_09:37:24]/dev/mmcblk3p7: Created a new partition 7 of type 'Linux' and of size 8 MiB.
20180808_09:37:24]/dev/mmcblk3p8: Created a new partition 8 of type 'Linux' and of size 4 MiB.
20180808_09:37:24]/dev/mmcblk3p9: Created a new partition 9 of type 'Linux' and of size 2 MiB.
20180808_09:37:24]/dev/mmcblk3p10: Created a new partition 10 of type 'Linux' and of size 2 MiB.
20180808_09:37:24]/dev/mmcblk3p11: Created a new partition 11 of type 'Linux' and of size 1 MiB.
20180808_09:37:24]/dev/mmcblk3p12: Created a new partition 12 of type 'Linux' and of size 1 MiB.
20180808_09:37:24]/dev/mmcblk3p13: Created a new partition 13 of type 'Linux' and of size 1 GiB.
20180808_09:37:24]/dev/mmcblk3p14:
20180808_09:37:24]New situation:
20180808_09:37:24]
20180808_09:37:24]Device          Boot   Start      End  Sectors  Size Id Type
20180808_09:37:24]/dev/mmcblk3p1          2048    83967    81920   40M 83 Linux
20180808_09:37:24]/dev/mmcblk3p2         83968   149503    65536   32M 83 Linux
20180808_09:37:24]/dev/mmcblk3p3        149504  7174143  7024640  3.4G  5 Extended
20180808_09:37:24]/dev/mmcblk3p4       7174144 61071359 53897216 25.7G 83 Linux
20180808_09:37:24]/dev/mmcblk3p5        151552  3911679  3760128  1.8G 83 Linux
20180808_09:37:24]/dev/mmcblk3p6       3913728  4962303  1048576  512M 83 Linux
20180808_09:37:24]/dev/mmcblk3p7       4964352  4980735    16384    8M 83 Linux
20180808_09:37:24]/dev/mmcblk3p8       4982784  4990975     8192    4M 83 Linux
20180808_09:37:24]/dev/mmcblk3p9       4993024  4997119     4096    2M 83 Linux
20180808_09:37:24]/dev/mmcblk3p10      4999168  5003263     4096    2M 83 Linux
20180808_09:37:24]/dev/mmcblk3p11      5005312  5007359     2048    1M 83 Linux
20180808_09:37:24]/dev/mmcblk3p12      5009408  5011455     2048    1M 83 Linux
20180808_09:37:24]/dev/mmcblk3p13      5013504  7110655  2097152    1G 83 Linux
20180808_09:37:24]
20180808_09:37:24]Partition table entries are not in disk order.
20180808_09:37:24]
20180808_09:37:24]The partition table has been altered.
20180808_09:37:24]Calling ioctl() to re-read partition table.
20180808_09:37:24]Syncing disks.
20180808_09:37:24]Checking that no-one is using this disk right now ... OK
20180808_09:37:24]
20180808_09:37:24]Units: sectors of 1 * 512 = 512 bytes
20180808_09:37:24]Disklabel type: dos
20180808_09:37:24]Disk identifier: 0x6c9d2afd
20180808_09:37:24]
20180808_09:37:24]Old situation:
20180808_09:37:24]
20180808_09:37:24]
20180808_09:37:24]
20180808_09:37:24]/dev/mmcblk3p1:
20180808_09:37:24]
20180808_09:37:24]/dev/mmcblk3p1         16384    81919    65536   32M 83 Linux
20180808_09:37:24]/dev/mmcblk3p7       4964 mmcblk3: p1 p2 p3 < p5 p6 p7 > p4
20180808_09:37:24]352  4980735    16384    8M 83 Linux
20180808_09:37:24]
20180808_09:37:24]
20180808_09:37:24]UTP: sending Success to kernel for command $ sh mksdcard-android.sh /dev/mmcblk3.
20180808_09:37:24]UTP: received command '$ ls -l /dev/mmc* '
20180808_09:37:24]UTP: executing "ls -l /dev/mmc* "
20180808_09:37:25]brw------- 1 root root 179,  0 Jan  1 00:00 /dev/mmcblk3
20180808_09:37:25]brw------- 1 root root 179,  8 Jan  1 00:00 /dev/mmcblk3boot0
20180808_09:37:25]brw------- 1 root root 179, 16 Jan  1 00:00 /dev/mmcblk3boot1
20180808_09:37:25]brw------- 1 root root 179,  1 Jan  1 00:00 /dev/mmcblk3p1
20180808_09:37:25]brw------- 1 root root 179,  2 Jan  1 00:00 /dev/mmcblk3p2
20180808_09:37:25]brw------- 1 root root 179,  3 Jan  1 00:00 /dev/mmcblk3p3
20180808_09:37:25]brw------- 1 root root 179,  4 Jan  1 00:00 /dev/mmcblk3p4
20180808_09:37:25]brw------- 1 root root 179,  5 Jan  1 00:00 /dev/mmcblk3p5
20180808_09:37:25]brw------- 1 root root 179,  6 Jan  1 00:00 /dev/mmcblk3p6
20180808_09:37:25]brw------- 1 root root 179,  7 Jan  1 00:00 /dev/mmcblk3p7
20180808_09:37:25]brw------- 1 root root 179, 24 Jan  1 00:00 /dev/mmcblk3rpmb
20180808_09:37:25]UTP: sending Success to kernel for command $ ls -l /dev/mmc* .
20180808_09:37:25]utp_poll: pass returned.
20180808_09:37:25]UTP: received command 'send'
20180808_09:37:25]UTP: sending Success to kernel for command send.
20180808_09:37:25]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4096 count=16'
20180808_09:37:25]UTP: executing "dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4096 count=16"
20180808_09:37:25]0+1 records in
20180808_09:37:25]0+1 records out
20180808_09:37:25]422 bytes copied, 0.00953133 s, 44.3 kB/s
20180808_09:37:25]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4096 count=16.
20180808_09:37:25]UTP: received command 'frf'
20180808_09:37:25]UTP: closing the file
20180808_09:37:25]UTP: sending Success to kernel for command frf.
20180808_09:37:25]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4608 count=16'
20180808_09:37:25]UTP: executing "dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4608 count=16"
20180808_09:37:25]422 bytes copied, 0.00955433 s, 44.2 kB/s
20180808_09:37:25]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3 bs=512 seek=4608 count=16.
20180808_09:37:26]utp_poll: pass returned.
20180808_09:37:26]UTP: received command 'frf'
20180808_09:37:26]UTP: closing the file
20180808_09:37:26]UTP: sending Success to kernel for command frf.
20180808_09:37:26]UTP: received command 'send'
20180808_09:37:26]UTP: sending Success to kernel for command send.
20180808_09:37:26]UTP: received command '$ dd if=$FILE of=/dev/mmcblk3p1'
20180808_09:37:26]UTP: executing "dd if=$FILE of=/dev/mmcblk3p1"
20180808_09:37:27]15400+0 records in
20180808_09:37:27]15400+0 records out
20180808_09:37:27]7884800 bytes (7.9 MB, 7.5 MiB) copied, 0.87919 s, 9.0 MB/s
20180808_09:37:27]UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk3p1.
20180808_09:37:27]utp_poll: pass returned.
20180808_09:37:27]UTP: received command 'frf'
20180808_09:37:27]UTP: closing the file
20180808_09:37:27]UTP: sending Success to kernel for command frf.
20180808_09:37:28]utp_poll: pass returned.
20180808_09:37:28]UTP: received command '$ mkfs.ext4 -b 4096 -m 0 /dev/mmcblk3p4'
20180808_09:37:28]UTP: executing "mkfs.ext4 -b 4096 -m 0 /dev/mmcblk3p4"
20180808_09:37:28]mke2fs 1.43-WIP (18-May-2015)
20180808_09:37:28]Discarding device blocks: random: nonblocking pool is initialized
20180808_09:37:36]done
20180808_09:37:36]Creating filesystem with 6737152 4k blocks and 1687552 inodes
20180808_09:37:36]Filesystem UUID: 8d812130-cb4a-4881-a16e-2130a36fe608
20180808_09:37:36]Superblock backups stored on blocks:
20180808_09:37:36]        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
20180808_09:37:36]        4096000
20180808_09:37:36]
20180808_09:37:36]Allocating group tables: done
20180808_09:37:36]Writing inode tables: done
20180808_09:37:36]Creating journal (32768 blocks): done
20180808_09:37:38]Writing superblocks and filesystem accounting information: done
20180808_09:37:38]
20180808_09:37:38]UTP: sending Success to kernel for command $ mkfs.ext4 -b 4096 -m 0 /dev/mmcblk3p4.
20180808_09:37:38]utp_poll: pass returned.
20180808_09:37:38]UTP: received command '$ mkfs.ext4 /dev/mmcblk3p5'
20180808_09:37:38]UTP: executing "mkfs.ext4 /dev/mmcblk3p5"
20180808_09:37:38]mke2fs 1.43-WIP (18-May-2015)
20180808_09:37:39]Discarding device blocks: done
20180808_09:37:39]Creating filesystem with 470016 4k blocks and 117600 inodes
20180808_09:37:39]Filesystem UUID: c67f8aa6-55f6-4a57-b325-004ca3c1b7b1
20180808_09:37:39]Superblock backups stored on blocks:
20180808_09:37:39]        32768, 98304, 163840, 229376, 294912
20180808_09:37:39]
20180808_09:37:39]Allocating group tables: done
20180808_09:37:39]Writing inode tables: done
20180808_09:37:40]Creating journal (8192 blocks): done
20180808_09:37:50]Writing superblocks and filesystem accounting information: done
20180808_09:37:50]
20180808_09:37:50]UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk3p5.
20180808_09:37:50]utp_poll: pass returned.
20180808_09:37:50]UTP: received command '$ mkfs.ext4 /dev/mmcblk3p6'
20180808_09:37:50]UTP: executing "mkfs.ext4 /dev/mmcblk3p6"
20180808_09:37:50]mke2fs 1.43-WIP (18-May-2015)
20180808_09:37:50]Discarding device blocks: done
20180808_09:37:50]Creating filesystem with 131072 4k blocks and 32768 inodes
20180808_09:37:50]Filesystem UUID: cbae988a-6f99-4a43-a9bc-1dba13fe73e5
20180808_09:37:50]Superblock backups stored on blocks:
20180808_09:37:50]        32768, 98304
20180808_09:37:50]
20180808_09:37:50]Allocating group tables: done
20180808_09:37:50]Writing inode tables: done
20180808_09:37:50]Creating journal (4096 blocks): done
20180808_09:37:50]
20180808_09:37:50]UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk3p6.
20180808_09:37:50]UTP: received command '$ ls -l /dev/mmc* '
20180808_09:37:50]UTP: executing "ls -l /dev/mmc* "
20180808_09:37:50]brw------- 1 root root 179,  0 Jan  1 00:00 /dev/mmcblk3
20180808_09:37:50]brw------- 1 root root 179,  8 Jan  1 00:00 /dev/mmcblk3boot0
20180808_09:37:50]brw------- 1 root root 179, 16 Jan  1 00:00 /dev/mmcblk3boot1
20180808_09:37:50]brw------- 1 root root 179,  1 Jan  1 00:00 /dev/mmcblk3p1
20180808_09:37:50]brw------- 1 root root 179,  2 Jan  1 00:00 /dev/mmcblk3p2
20180808_09:37:50]brw------- 1 root root 179,  3 Jan  1 00:00 /dev/mmcblk3p3
20180808_09:37:50]brw------- 1 root root 179,  4 Jan  1 00:00 /dev/mmcblk3p4
20180808_09:37:50]brw------- 1 root root 179,  5 Jan  1 00:00 /dev/mmcblk3p5
20180808_09:37:50]brw------- 1 root root 179,  6 Jan  1 00:00 /dev/mmcblk3p6
20180808_09:37:50]brw------- 1 root root 179,  7 Jan  1 00:00 /dev/mmcblk3p7
20180808_09:37:50]brw------- 1 root root 179, 24 Jan  1 00:00 /dev/mmcblk3rpmb
20180808_09:37:50]UTP: sending Success to kernel for command $ ls -l /dev/mmc* .
20180808_09:37:50]UTP: received command '$ mkfs.ext4 /dev/mmcblk3p13'
20180808_09:37:50]UTP: executing "mkfs.ext4 /dev/mmcblk3p13"
20180808_09:37:50]The file /dev/mmcblk3p13 does not exist and no size was specified.
20180808_09:37:50]UTP: sending Non-success to kernel for command $ mkfs.ext4 /dev/mmcblk3p13.
20180808_09:37:50]utp_poll: exit with status 256
标签 (4)
0 回复数
