Yocto Dunfell GSTREAMER build fails - imx6qdlsabreauto - fsl-framebuffer
ycardaillac
There's an issue with gstreamer build with imx6qldsabreauto and fsl-framebuffer distro.
I've been reproducing with upstream bsp. Find the repo complete info here : https://pastebin.com/abwRtKAY
meta-freescale : ae2001935fdd7cf7ee7e3b8a4826d7b59202be6d
fsl-community-bsp-base : 5a551f453260bd19895e4d847877874eaa51fde3
meta-freescale-3rdparty : f37f72a85ba273b27347169b727c889f42b91d6c
meta-freescale-distro : 5d882cdf079b3bde0bd9869ce3ca3db411acbf3b
meta-openembedded : 6792ebdd966aa0fb662989529193a0940fbfee00
poky : 90a6f6a110ab14890e2f6a1616e74ee259fc0f8f
Steps to reproduce :
git clone https://github.com/Freescale/fsl-community-bsp-platform.git
cd fsl-community-bsp-platform/
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b dunfell
repo sync
DISTRO=fsl-framebuffer MACHINE=imx6qdlsabreauto source ./setup-environment build
bitbake fsl-image-machine-test
Relevant part of the failure of gstreamer1.0-plugins-base_1.16.imx :
| Package gstreamer-audio-1.0 was not found in the pkg-config search path.
| Perhaps you should add the directory containing `gstreamer-audio-1.0.pc'
| to the PKG_CONFIG_PATH environment variable
| No package 'gstreamer-audio-1.0' found
| Package gstreamer-video-1.0 was not found in the pkg-config search path.
| Perhaps you should add the directory containing `gstreamer-video-1.0.pc'
| No package 'gstreamer-video-1.0' found
How can I solve this issue?
Yann
Zhiming_Liu
Hi @ycardaillac
We provide official support for kirkstone , hardknott ,honister ,gatesgarth ,zeus ,sumo ,thud ,warrior.
Please follow our document to build yocto:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
Zhiming
